Footswitch circuit in Marshall 2466 100W Vintage Mordern Amp doesn't work. Footswitch OK, Reverb OK, Dynamic Range OK. Just the circuit for switching verb on/off and dynamic range on/off doesn't work. Can you advise or at least send a pdf of the schematic? Thanks so much!
  • turnitupto10 May 20, 2009
    Thanks, that's great! I can take it from here. Really appreciate your help!
    Brigadier General:
  • 8,619 Answers
Hi
You can download the schematic from this link, it is for a similar model. This link contains repair tips--
Marshall 2466 100W Vintage Modern Amp Schematic
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 20, 2009
How can I fix reverb?
Either the spring driver circuit blew or the SPRING INSIDE BROKE.
You gotta get in there. Take out the spring unit and check if there is a tensed spring in there. If so, check the connectors. Also check the footswitch plug in the back of the amp, plug and unplug a cable several times, sometimes it becomes dirty and does not let signals through. You can check if the reverb has no drive by tapping the spring while the amp is on and the reverb volume is up. If it sounds, your reverb is fine but not receiving input. That would be the driver circuit. Take it to a Tech and explain.... GOOD LUCK !
Apr 30, 2014 | Stagg 40AA R 40W Acoustic Guitar Amplifier...
Just got a new Marshall DSL40C. The reverb does not work on either gain control or with the footswitch. Why?
Nothing wrong with the amp. Google it- these amps have extremely weak reverb. All of them are the same. It's the one weak point about these amps. And I love mine. I mic it when we gig. Sounds awesome both clean and driven. But you'll have to get a separate reverb pedal if you want "girl crush" or "pipeline" reverb. Don't listen to the above posters. It's the way these amps are.
Nov 30, 2013 | Marshall Music
Marshall MG250dfx problem
Did you already open the amp? Can you send me a closeup picture of the PCB?
Is there any relay? I wonder how the signal is switched between the two pre-amp channels: Either there is a relay (I think so) or the signal is switched directly via the switch on the front. I dont expect optocouplers or switching directly in your footswitch.
So check relay and switch with a circuit / continuity checker
Nov 23, 2013 | Audio Players & Recorders
Doesn't work !!
That footswitch is the right one for the HAZ40 but, it is programmable. I recommend downloading the manual and follow the instructions for programming and make sure you are using it properly.
Mar 05, 2013 | Marshall Amplification Marshall PEDL10049...
MARSHALL FOOTSWITCH FOR DSL100 TROUBLES
Does your M foot switch work on the Fender? If you know how to use a multimeter you could check continuity by putting meter leads on plug of M foot switch(1 on tip, 1 on sleeve ) You should see a change in the multi meter when you depress switch. If so switch is good. Another easy test is with cap off a spare 1/4 plug -plug it in to foot switch jack.put a alligator or some such metal clip or wire and join(called short or shorting) the two inputs . If connecting and unconnecting results in switching then the foot switch is suspect. One fairly common thing is that foot switch and input jack are often sautered straight to a circuit board to save $ on production cost. Used to be all point to point where a wire was attached to 1/4" input and then wire went to circuit board or tubes. The wire has give, but not so with direct wiring to board. So the nut holding the 1/4" amp input gets loose(doesn't have to be loose for the following to happen) and a pull on the chord causes a break in the soldier and thus a break in the sound chain. Sometimes it will work intermittingly by putting a little pressure left, right, up or down on the plugged in plug. If so, it's the input jacks connection to the amp. If not it still could be that because putting pressure on plug may not be sufficient to affect a temporary reconnection. Since switch(the new one you made)works on Fender, but not Marshall I suspect the jack or foot switch circuitry past the input jack. If using some of the above the above tests leads you that direction,remove housing(unplug a/c power 1st ) inspect jack,wiggle it slightly see or feel a break then resodier from back side. You should be able to use the soldier already present without adding extra.
Sep 27, 2017 | Music
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
Hi i have the Marshall MG15FXMSDM Dave Mustaine Megastack and i also have the programmable footswitch. the other day, i was plugged into a big surge protector and the footswitch was working fine. i...
First thing is to verify the MAIN power source is getting to the amp. It may not be the fault of the footswitch at all. Connectors and cables are the usual cause of these problems. Seating of connectors is a common problem...
Mar 02, 2011 | Marshall Amplification Marshall MG Series...
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hi, I have a Marshall 8240. The Reverb output
probably the reverb tank These coils are very thin and tent to break easily
Nov 05, 2009 | Marshall Amplification Marshall MG250DFX...
131 people viewed this question
 Grubhead
Grubhead
