Question about Garden
Mower wont stay running with out being on full choke and manualy movinging the auto advance lever
Mower is a rover E5000 have cleaned the spark plus new fuel and line also drained the fuel all comes out clean thank you for any help
  • 9,845 Answers
The fuel jet in the carburetor is gummed up. You'll have to disassemble the carb to get to the jet. spray some carburetor cleaner with the small tube in the nozzle on the jet to clear the gummy build up
Posted on Jan 29, 2014
  • 20 Answers
SOURCE: Craftsman Wee trimmer will only run when tilted on its side.
its your flaot in your little carb
Posted on Mar 24, 2009
  • 130 Answers
SOURCE: Ryobi 725 R runs only when choked, full throtle
you will have to rebuild carb.red and yellow caps just pull off you might have to get a tool to ajust carb and take them out
Posted on Jul 18, 2009
  • 163 Answers
SOURCE: Must run almost fully choked
sometinge in fuel lines or filter or carb is pluged try gun out
Posted on Jul 26, 2009
  • 5 Answers
SOURCE: trimmer wont stay running
the top line from the gas tank goes to the front nipple on the carb, the lower line from the gas tank goes to the back nipple on the carb
Posted on Sep 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: tempermental throttle/engine easily floods and stalls out
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
My troy built riding mower won't run full throttle it only run at about half throttle
if it runs good at half throttle, it just wont throttle up it sounds like the throttle cable has slipped. you might try to adjust it to get full throttle back .but if when you turn it up to full throttle and it dies then you have a choke, carburetor, fuel line, fuel filter or fuel tank problem. hope this gives you an idea.
Mar 29, 2016 | Troy Garden
Model lv195ea
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
May 09, 2013 | Toro Garden
Poulan pro honda engine stalls as auto choke lever moves
it sounds to me that there s a jet inside the carb that is still plugged
Jun 24, 2012 | Poulan Pro " Pro" Self Propelled Mower
Mower starts, but dies immediately
that's not a choke lever, it's used as a speed control on some models. the two springs are attached to the governor rod, which is attached to an "air vane" governor - on these engines, you need to keep the gas tank fairly full at all times, the dip tube on the carburetor rides up off the bottom of the gas tank, if fuel level goes lower than this tube, it won't pull any gas to the intake - from your descriptions, though, it sounds like the diapragm between the carb and gas tank has "curled". briggs had a service flash on the problem and since it's new, you should take it to a shop that does briggs warranty work - it should be covered under warranty
Aug 27, 2009 | Mtd 22" Yard Machine Push Mower
Rover lawn mower is not working
Make sure you get a spark, Clean the gas tank, maybe even go as far as cleaning the carb, make sure everything is like new and start it up.
Jun 21, 2009 | Garden
I have a DYT400 with a Briggs and Straton Intek plus 19.5 ovh. When I move the speed lever to full speed, the mower wants to choke out. Also, when I put the lever on stop, it just keeps running. the...
You have governor with a missing spring or it could be in the wrong place. If the springs are all OK then you may have a bad governor gear in the crankcase. This engine is bad about the governor gears bending the governor gear shaft.
Apr 25, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Range rover classic lwb 4.0
Check your earth wires on the gearbox and engine , check that no air intake pipes or vacuum hoses have come off with the engine tilting when you replaced the gearbox.Also check the brake vacuum hose.
Nov 23, 2008 | 1994 Land Rover Range Rover County
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
