Question about HP W17E 17" Flat Panel Monitor
Hp w17e monitor randomly shuts off and turns back on
I used this monitor for almost 3 or 4 years. it started few days ago. the monitor keeps turning off randomly and turns back on. sometimes it turns off and on like 6 times a minute or occurs every 3 hours. it turns off the monitor goes black and the green light shuts off. few seconds later it turns back on and the led light becomes green. it can turn back on 5 seconds after it turns off or even half an hour later. when it turns off and doesn't turn back on for few minutes i press the menu, auto, or the power button randomly and it turns back on. the problem is very random and impractical. i know the monitor is causing the problem because i hooked up a different monitor to my pc and it works fine. the power and dvi connections are fastened securely and i cleaned the monitor with canned air spray.
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
  • 3 Answers
SOURCE: hp 42in plasma tv
There is some voltages that need adjusted in your tv and possibly the z sustain board needs replaced if the voltage adjustment doesn't fix it.
Posted on Jan 14, 2008
  • 38 Answers
SOURCE: monitor randomly shuts down
This is either power supply (not usually), backlight drawing to much current, or most likely an invertor board component failure. Built in overcurrent protection on many of these boards will provide a shutdown signal. Weak transistors will crash when they get hot. Hp monitors are notorious for inverter problems. The time between blackouts will decrease until it no longer will light at all. Repair or replace the invertor.
Posted on Jan 15, 2008
SOURCE: Auto Adjustment keeps turning on every few seconds
I have had the same problem and now suspect that cleaning fluid from when I cleaned the screen may have seeped in. After a number of things I did over a period of 2 weeks the problem went away completely.
1. You may be able, if that is your problem, solve it quicker with a hair dryer at a distance (no melt down!)
2. Run HP diagnostics and clean the registry
3. Re- install drivers
Like I said I think 1 is the most likely. I went from every couple of seconds to completely solved.
Another possibility is that an MS update may have caused the problem and then another solved it.
Posted on Jan 11, 2009
jscruggs420
  • 36 Answers
SOURCE: HP Plasma TV - Lost Picture
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
Posted on Feb 04, 2009
Hp w17e not powering up
Try unplugging the power cable then pressing the ON button few times (yea, while the power cord is unplugged although it may sound silly), afterwards plug the power cable back in and try turning the screen on, if still don't works then its probably one or few capacitors have leaked and need to bee replaced.
  • If you still have warranty on it then its the time to use it,
  • If not you can try fixing it at an electric shop or try opening it by yourself, find out what capacitors are damaged and replace them.
Feb 13, 2011 | HP w17e Monitor
I have an emachines E181H TFT LCD monitor and a few months ago it would turn off at random and would come back on.After a few days it stopped turning off by itself I have had no problems till recently,...
After a while LCD monitors develop problems that are usually caused by faults in the internal circuitry. This could be an issue with the power capacitors failing. If you feel confident enough, you can remove the back cover and check to see if any capacitors are bulging or leaking. (Give it at least 24 hours unplugged to allow the capacitors to discharge before doing so). I found THAT little bit of knowledge out the hard way
Jan 22, 2011 | Acer AL2017 20" LCD Monitor
My hp w17e will only work for about 5-7 seconds when I first turn it on, and then goes blank. If I turn it off and back on again, the same thing happens. Is it fixable?
You should do some research here first: www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ It's an old blog, but could offer a solution worth exploring. Just remember to rate this response after you do your research there. 12fixlouie
Sep 25, 2010 | HP w17e Monitor
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
It stays on only for a few seconds then it turns off.
More likely to be bad capacitors in the power supply for this 2007 model year, that will be the first place to check, look for caps with bulging top/seal, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 12, 2010 | HP w17e Monitor
Paloma PTG-74PVN power turns off by itself
turn the water flow off and control off and hold the two arrow buttons together
then use the up arrow to get to e and the down arrow to get to 1 what do you see?
Sep 09, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a HPw1907 monitor and it will turn on for about 2 seconds, and it turns off. The CPU is fine, just a problem with the monitor. Any way to fix this?
We have the same model of monitor and had the same problem few days ago. The monitor just goes black/turns off. I noticed that the power button has a yellow blinking light and cannot be turn on/off again using the power button. The CPU is working fine also. When I turn off the avr, the power button's light turns blue for a few second and you can hear a click sound from the back of the lcd before it totally turns off. My lcd monitor is over a year old now and is 110v or 220v capable. Mine was originally in a 220v, i just put it in 110v and the monitor was fixed.. Hope this can somehow fix your problem.
Aug 02, 2009 | HP w1907 LCD Monitor
HP w17e monitor
i had this problem as whell for the HP w17e or maybe others, you turn off the monitor then press and hold the menu button and while you are still holding the menu button turn on the monitor and hold it still for 2 seconds and you are done. Hope this helps
Feb 18, 2009 | HP w17e Monitor
Identify cable & where to connect to get audio on HP w17e monitor
male mini-stereo to male mini-stereo
Plug into LIME GREEN port on computer.
Dec 28, 2008 | HP w17e Monitor
HP W17E 17" Flat Panel Monitor Logo
14 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
