Question about Canon PC-941 Copier
Canon 941 prints black - Canon PC-941 Copier
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
I can not reset Eo on my canon pc 941
You don't. You have to replace the fixing film assembly of the copier. The fuser is not heating up correctly and is creating the error.
Apr 29, 2011 | Canon PC-941 Copier
Canon PC 941 dark copies. has new toner cartridge. dark and light control wont work. what is the problem ?
Clean the optical section,mirrors,lamps.Open the front cover and you see one adjust switch or rotative button placed in the center under dispalys.For light/dark rotate to adjust.
Nov 20, 2009 | Canon PC-941 Copier
Need charger
The replacement DM-XM2 replacement battery charger is @ http://www.ebuybatteries.com/product/battery_chargers/Canon/Canon-BP-941-AC-charger.htm , note it is an extern battery charger, not a power adapter.
Sep 12, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
Canon PC 941 copier. Paper jam indicated with no paper.
Can be that sensor of the passing of the paper or was broken off flag, or sensor has wedged in position james, more often such can be in block of the fastening, when paper stuck extract. Try its see, this possible behind do. Good luck
Sep 04, 2009 | Office Equipment & Supplies
Copies come out black
the expose lamp turns on when you start a copy,if not must change the lamp,the cartidge is ok.
Jul 06, 2009 | Canon PC-941 Copier
I can only print the 941 form in quickbooks. Nothing else.
Open QuickBooks and go to file at the top left of the screen. Click on it. This will give you a drop down list. Choose "printer set up". This will give you a list of forms. Choose the name of the form you want to be able to print while in QuickBooks and this will take you to an area to choose your default printer. Click the arrow next to the name of the printer you want to use to print your forms and then save and close the window.
May 05, 2009 | Intuit QuickBooks Premier Contractor 2008:...
Paper will not feed from drawer
Pull the paper tray out of the machine. On the right side underneath you should see a rubber paper feed roller. Clean this off with a slightly damp cloth until it is "squeaky clean". Also, look about to be sure there is nothing blocking the paper path. Sometimes paper gets torn off and left in the machine when clearing a jam.
Apr 21, 2009 | Canon PC-941 Copier
Canon PC-941 Copier Logo
23 people viewed this question
old marine
old marine
