Question about Nordic Track NordicTrack Treadmill, A2550
My nordic track c2300 starts up and after one second stops
It starts for one second and stops
maxtreadmill
  • 832 Answers
SOURCE: My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Posted on Feb 28, 2010
maxtreadmill
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
maxtreadmill
  • 832 Answers
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Posted on Jun 14, 2010
  • 218 Answers
SOURCE: Hello, I have a Nordic Track 2050, and got on this
console is bad no other alternative, check ebay for part
Posted on Aug 11, 2010
SOURCE: My Nordic Track exp 1000x started stopping after
Your walk belt is worn. The friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside) When the belt wears out the cloth on the underside becomes flattened causing too much surface area to contact the walk board
Posted on Aug 23, 2010
Power surging
sounds like the treadmill is drawing too many amps. try using a larger surge protector.
Feb 19, 2014 | Nordic Track NordicTrack C2300 Treadmill
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
Mar 26, 2013 | Nordic Track NordicTrack A2350 Pro...
My t7 si is beeping continually and starts for a few seconds and stops
lube the deck belt+rollers bearing . If the problem persist, time to change the deck belt board complete.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack T7 si Treadmill
Belt on Nordic Track T4.0 treadmill stops
Dear Sir:
1) Lube the treadmill in according with the instruction manual.
2) The reason is lack of lube by maintenance, that produce enough friction with shut down for to protect electronic system.
3) Test the deck belt if is worn, and replace it.
4) Test the rollers bearings
5) See the bearing motor
6) Test the input voltage motor coming from the output from the main motor board,, use DVOM.
7) See my personal TIPS for HELP.
sincerely. God bless you
Apr 23, 2012 | Nordic Track Exercise & Fitness
Jul 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Treadmill, A2550 Logo
24 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
