Question about Gaggia Classic Espresso Machine
Gaggia classic, still drips coffee
Gaggia classic two weeks old, drips coffee after pulled shot and switched ot milk frothing function. Steam is leakier too. Didn't do that initially.
  • Dan
    Dan May 11, 2010
    Is your Gaggia new and still under warranty or was it purchased used/abused?
    President:
  • 1,618 Answers
Where is the drip for the coffee happening,is it around the portafilter, or the tube hanging in the drain tray on the left, or from the shower in the grouphead.
1- Around portafilter..since the machine is only 2 wks old the it is possible that coffee grounds are on the gasket in the head, get a hard toothbrush or buy a groupbrush and clean group gasket also check for damage.
2- Tube in drain tray...If it is a continuous drip whenever the machine is on then the nucleus in the solenoid is either dirty or damaged, try backwashing the machine. If it happens only when you make a coffee then that is the discharge on the solenoid working. Run a backwash on the group and that will cleann out the discharge.
3- If it is coming from the shower in the group then the solenoid needs to be replaced.
As for the steam wand leak it sounds as though the valve is not closing. That will have to be replaced because it cannot be rebuilt.Gaggia classic, still drips coffee - 5547512.jpg
Posted on May 21, 2009
Lacks correct steam for milk froth
Requires cleanout and service,no quick fix
Jan 16, 2013 | Gaggia Classic Espresso Machine
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Frothing attachment coming off from pressure
Check the holes in the attachment they might be blocked and the pressure of the steam is blowing it off.
Apr 14, 2010 | Gaggia Classic Espresso Machine
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
My steam function more water than steam comes out. Yhe thermostat is turning on and off but when you open the steam valve you end up with more water than steam??? To froth the milk i have to do 4...
Replace the thermostat for the steamvalve, it is not keeping the element on long enough or you need to descale boiler because there is not enough room for water.
Jan 30, 2010 | Gaggia Classic Espresso Machine
Gaggia Coffee Classic Steam Valve Leaking - No Pressure!!
Yes it can be repaired if you have the parts, you will need the complete steam valve with the o-ring that connects to the boiler check the diagram below.
Aug 21, 2009 | Gaggia Coffee In White, White MDF...
Missing cap, making frothing impossible and not enough pressure f
Remove the shower screw and shower screen, there you will see 2 allen wrench screws, remove them they hold the diffuser in place, then check the spring valve that is in the middle hole that migt be stuck (scale buildup), clean and test machine. Check diagram.2ab301a.jpg
Jun 29, 2009 | Gaggia Classic Espresso Machine
Losing steam
Try to descale the machine to see if will be better.
Aug 13, 2008 | Gaggia Classic Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Gaggia Classic Espresso Machine Logo
220 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
