Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Network error 00204697 on philips 46plf3608fl
How do I connect to a wireless network with a Philips model 32PFL5403D/F7 TV?
The Philips 32PFL5403D/F7 is not a Smart TV and can only be connected to a network through a set-top or streaming stick. The ChromeCast, Roku Stick, Roku 3, or AppleTV are examples that would work. The hotspot would not be recognized by the TV since it can't access the needed data (drivers, etc). The Playstation Wii should communicate with your wireless network and connect to the TV via the composite input on the TV. Make sure that you know the router password. The Wii supports WEP and WEP encryption. (If you have a problem viewing the Wii content on the Philips set, make sure that you used the composite output and used the Wii cable. Ordinary composite video cables don't work.)
An error of 51330 or 52130 from the Wii means that the password that you entered was not accepted by the router (or hotspot). You should have a device that is already connected to the hotspot, use that to check the SSID and password. Please add a comment with information about the model of hotspot for additional assistance. The information should be under Settings > Wi-Fi for most models but it may vary. (Check that the hotspot isn't in a sleep mode and that you are close to the Wii and still get a strong connection to your cell network.)
(If you are using a router to extend your network, I recommend using a wired connection to check the wi-fi network SSID and password. You have to log into the router to check or change things. If you reset the wireless network during this, you lose your connection to the router.)
Jan 06, 2015 | Video Game Consoles & Games
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
I have a Philips sound bar and I need the code to add it to my dish network remote
It would be our pleasure in assisting you with this. Pleaseknow that the code provided will only work with either the 20.0 or 21.0remotes. We want to start with pressing and holding the AUX button located onthe top of your DISH Network remote control until all mode button back lights come on, then release. Once the AUX button is blinking, on the numberpad enter 2* then anyone of these codes: 733, 640, 685, or 725. Once thecode as been entered, press the pound (#) button. Check that the code works by trying several differentfunctions on the remote to make sure it properly operates your Philips soundbar. Keep in mind that some codes may not be compatible with your equipment.
We hope this helps, and thanks for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Support Representative
Dec 09, 2010 | Philips Code Free DVD Player
I need the remote code can't find it i have a dish network universal any help would be appreciated.
We would be happy to help you with that. Here is a list ofcodes that should address your DISH Network remote to your Philips Magnavox DVD Recorder: 801, 766, 556, and 585.
Press and hold the DVD/VCR button located on the top of the remote until allthe mode buttons at the top of the remote light up, then release. Use thenumber buttons to enter one of the codes for your Philips Magnavox DVD Recorder, then pressthe pound (#) button. If the code entered is valid for the remote, the modelight flashes three times.To check that the code works try several different functions on the remote tomake sure it will properly operate your Philips Magnavox DVD Recorder. Keep in mind that somecodes may not be compatible with your equipment. If this is the case, try the other codes listed for that device until you find one that iscompatible with your equipment. We hope this helps and thank you forbeing a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 01, 2010 | Philips Magnavox MWR10D6 DVD Recorder
Format philips go gear mp3 player
There is a support page that explains the format procedure for the SA3125 player. It is available here:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview?scy=PH&subrequest=1&mid=Link_FAQs&session=20090130135307_66.249.71.73&desc=Philips+GoGear+Flash+audio+video+player+SA3125+2GB*&view=aa12_view_full.html&list=aa12_list_partial.html&slg=ENG&refnr=0064745&refdisplay=PI_C35_SA3XXX_030&dct=QAC&ctn=SA3125/97
Jan 25, 2009 | Philips GoGear SA3125/37 MP3 Player
I installed 4gb of memory 4x1GB 240 pin and when booting up the computer recieved the decomplilation or disassembly prohibited.  What do I do?
HI there,
If you have installed the memory module correctly and are the right ones, than go into your bois and in there should be overwrite o clear this message.
Its only an alert message when you pc has been opened.
Regards,
Philip
Dec 06, 2008 | Dell Optiplex GX280 (99301) Motherboard
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
398 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
