Question about HP Photosmart 2710 All-In-One InkJet Printer
Troubleshooting remove and check cartridge color
ve3wtj
  • 147 Answers
SOURCE: remove and check color cartridge
Sounds like the contacts are dirty. A cotton swab and some rubbing alcohol might help.
Posted on Sep 19, 2008
  • 81 Answers
SOURCE: Color cartridge
Yes, it sounds as if you do need a new color cartridge
Posted on Dec 16, 2008
  • 72 Answers
SOURCE: HP4150 error "remove and check color cartridge"
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the carriage is idle and silent.
  3. Press down gently on the top of the cartridge to release it.
  4. Make sure all the clear protective tape has been removed from the nozzle and electrical contact area
  5. Reinstall the cartridge in the product and try again to print.
  6. : Make sure the cartridge is compatible
  7. Open the printer lid and wait until the carriage stops moving, and then unplug the power cord.
  8. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
  9. Dip a clean cotton swab in distilled water, and then squeeze it to remove most of the moisture.
  10. Clean the print cartridge contacts. Do not touch the nozzles.
  11. Clean the contacts inside the carriage, inside the printer.
  12. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  13. Reinstall the cartridge, plug in the power cord, close the printer cover, and then try again to print.
Posted on Aug 08, 2009
  • 109 Answers
SOURCE: Message says Remove and check color cartridge. We
you should clean the gold contacts where the cartrige is inserted they may have ink deposits preventing contact to the cartrige good luck!
Posted on Sep 08, 2009
  • 12 Answers
SOURCE: Won't print: "remove and check color cartridge"
remove your new color cartridge and make sure you have removed the safety tape on the botton of the cartridge.
Posted on Mar 07, 2010
Printer error comes up "Remove and check color cartridge". Have done this and it won't clear. I am not even using color ink...what do I do?
Hi
There are two main reasons for this problem, one is that the colour cartridge has insufficient ink in it, even if not showing as such, and the other is that the cartridge is a compatible, and not being recognised, this can be the case even though the cartridge was accepted originally. Its worth noting that many printers will not print unless all cartridges are in full working order, even if the non-working cartridge is not required for the print job that is wanted.
I found a full manual here:
http://h10032.www1.hp.com/ctg/Manual/c00369567.pdf
which has some useful information about troubleshooting such issues.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Jan 04, 2015 | HP OfficeJet 7210 All in One Multifunction...
Laserjet hp ce3525dn has a yellow background and yelow layer over my color printing
1. Scroll to and touch Administration.
2. Scroll to and touch Troubleshooting.
3. Touch PQ Troubleshooting.
4. Touch Print.
Chk PQ test pages, if yellow color arrests entire page?.. Two reasons
1. Yellow cartridge.. ( swap with another one & chk )
2. Chk yellow cartridge contacts, clean them with isopropyl alcohol.
Chk base contacts, broken?, dis placed?, not contacting?..etc ...Remove & refix DC controller board...
May 07, 2014 | HP CP3525N Color LaserJet Printer
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
Apr 03, 2011 | HP Office Equipment & Supplies
Cartridge error refer device documentation troubleshoot
Remove the black cartridge and keep only the color cartridge in, and check the message. Now remove teh color cartridge and insert only the black cartridge in, and check the message. This should give an idea about which cartridge has a problem.
Feb 17, 2011 | HP Officejet 5610 All-In-One InkJet...
Cartridge error: refer to device documentation to troubleshoot
remove the cartridges and clean the metal contacts with tissue paper and put it back. if the problem continues check the cartridges.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Receiving a "Insert color cartridge" error message
You hit it! Go out and buy a new cartridge. Most likely you got a bad one.
Jun 19, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Will not print color
Hi!
Lets see if I can Help you.
first remove your color cartridge and check it protection tape was removed. If it was reinstall color cartridge and run your page test as if you were installing your printer the first time follow the instruction step by step.
There is also a troubleshooter section in your owners manual.
I need to know if your printer recognized the new ink cartridge when you in stalled it.
hope that helps.
Dec 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dell Photo 926 Printer Trouble
reinstall the printer driver
Mar 27, 2008 | Epson Printer
Printer will not print with color cartridge in
go to dell AIO center
click maintain/troubleshoot on the top
under trouble aio problems - click ink levels
click maintenace tabs
and then clean print cartridges and align print cartridges. then try printing a test page.
if this does not work, remove the cartridges and install them again.
let me know how it goes
Sep 08, 2007 | Dell Photo 964 All-In-One InkJet Printer
HP Photosmart 2710 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
