Question about Whirlpool WTW5100SQ
Need to get a plastic pulley attached to motor without motor
I have a Maytag washer. Belt is bad and the pulley that is evidently attached to the motor is melted (plastic). The motor doesn't seem to be siezed up but the appliance parts store can't sell me the pulley without the motor. Apparently Maytag does not sell them separately. Not sure why they ar plastic. Any suggestions besides buying a new washer?
    President:
  • 1,136 Answers
Hi, Is the plastic pulley on the motor or is it on the belt idler asswmbly? THe model # you have given is for a Whirlpool washer. This model doesn't have a belt. It has a coupler to connect the botor and transmission. Do have a model # for the maytag washer?
Vic
Posted on May 20, 2009
Maytag DG4000 dryer. Drum needs a little push to get the dryer going. Without the push the motor hums as though it's trying to go but then eventually quits. Any ideas?
1 phase suggest replace capacitor or wingdings in motor are damaged/ or it could be a bad electrical connection /supply to motor
myself i go for capacitor good luck.
Sep 22, 2016 | Maytag Dryers
How to replace the belt on the Maytag Neptune FAV6800AAW?
See if my Clutch Fix post will help. I also have links to Service Manual which will be big help. The drive belt can be walked on the Clutch Pulley but it is a very snug fit even with the drive belt tension bolt loosened. Watch you fingers as you walk the drive belt onto the clutch pulley….Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag MAV 7000 stopped in rinse cycle with water in tub. When turned on, there is a low buz sound. Was making a louder noise prior to stopping.
RepairClinic.com
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components.
Go here for: Maytag-Washing-Machine-Parts
May 05, 2009 | Maytag Atlantis MAV7000
Pulley broke
i am instructing on the motor pulley.it is plastic,get it off any way you can with out hurting the motor shaft.i think somtimes i would use large channel locks.you dont need to save any of it.
Jan 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
Jan 08, 2009 | Maytag MAV6200 Top Load Washer
Maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Jan 04, 2009 | Maytag Washing Machines
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Plastic pulley melting
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
Mar 15, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Belt installation
repacing the belt on a neptune is simple. unplug the unit and move it away from the wall.. now remove the 4 screws holding the access panel in place. loop the belt over the end of the motor shaft so that the grooved side of the belt catches the grooves on the shaft. now simply feed it around the tub pulley. if you find the belt keeps coming off you might have a bearing problem tht has caused the tub to shift. look for fine plastic powder, almost dust like, that would be the pulley eating into the back of the tub
Sep 04, 2007 | Maytag SAV5710 Top Load Washer
How to replace Maytag Washer belt
I have a model sav2655aww maytag washer. And it needs a new belt but I dont know how to replace it! Can the pump be removed with out removeing the motor ? Also the tub keeps going off center whats with that ?
Sep 03, 2007 | Maytag SAV5710 Top Load Washer
Whirlpool WTW5100SQ Logo
228 people viewed this question
Dan Webster
Dan Webster
Sal De
