Question about VinoTemp (VT60GNV) Wine Cooler
Temperature is stuck on 72 - VinoTemp (VT60GNV) Wine Cooler
Hi ive got a manual digital filtrete thermostat, it just started to not let me lower the temperature setting, its stuck and 72
It has a failure of course, but they do not make parts to repair them so you will need to replace the T-stat.
Nov 30, 2016 | Heating & Cooling
The temperature displayed on the front of our fridge is incorrect, How do I fix this?
possible that the rear of the fridge needs space for the condenser to get air to cool
Oct 24, 2015 | Refrigerators
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
What is the correct temperature for a gym class
gyms around here stay around 68 to 72, 68 summer and 72 winter. theres no way i could work out in 76 that would be very uncomfortable, if you are really working out your not going to be cold.. hope it helps
Nov 11, 2009 | Omega Trane Furnace Draft Inducer Blower ...
Kenmore dishwasher 665-16829000, #72 on control panel not going away
does it always say 72? will it start? you could have a stuck key on the consol.
Nov 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
VinoTemp (VT60GNV) Wine Cooler Logo
56 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
