Question about Kitchen Ranges
User manual jenn air
Our range is beeping and saying f7
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
jsrock516
  • 5911 Answers
SOURCE: F7 error message on all screens with beeps
F7 for a Fridgidaire Range indicates a failure with the electronic Range Control (ERC). Unfortunately when these fault codes pop up, the electronic boards must be replaced. The part number for yours is 937801 and costs about $190. Is it possible you may have gotten cleaner on the board or possibly shorted out the buttons? Is your range still covered under a warranty? Double check your paperwork and see if the electronics are covered for an extended period beyond the normal limited warranty you get when you purchase a new appliance. Post back with comments and/or questions if you wish to repair the range. I hope this helps you.
Posted on Jan 29, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn Air F7 error msg with incessant beeping
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
Posted on Dec 08, 2008
SOURCE: jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Posted on Feb 28, 2009
SOURCE: Jenn Air range model SVE47600 Beeping
range was beeping and showing code f4....would not stop unless i turned breaker off
Posted on Nov 12, 2009
Why won't it operate?
Hi Pam, Is this not covered in the user manual? Additionally search online by "error code f7 f1" and see what hits you get.
Jul 10, 2015 | Jenn-Air JJW9630C Expressions Collection...
Oven beeps and displays F7. Hit stop/cancel, starts up again in about 10 seconds
Hi cpwdavis,
The F7 failure code shows a Function key shorted or stuck. To resolve this problem, you need to replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Sep 22, 2011 | Jenn-Air JES9800A Electric Kitchen Range
Dec 08, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
Sep 09, 2008 | Jenn-Air SVE47100 Slide-In Electric...
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
F7 error message
f7 is listed as being a stuck membrane switch for longer than 30 seconds, a button is failed and is stuck in. replacemnet is on ly fix you cant repair active overlay switches
Feb 18, 2008 | Jenn-Air SCE30600 Slide-In Electric...
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
