Question about Vacuums
Power button not working - Vacuums
Power nozzle does not work. Light comes on on power nozzle but it does not vacuum
Many early version PN-2E power nozzles have reset buttons that are becoming faulty. The factory stopped adding the rest button to this model power nozzle so you can update your unit by removing and this my solve your issue. You have the trigger to stop the motor if you have an issue so the rest button has become unnecessary.
Mar 28, 2015 | Rainbow E series Canister Wet/Dry Vacuum
The power button will not stay depressed. Vacuum will work if I hold it down.
It is caused by loose power buttons Spring or broken lock. open the cover & replace power switch.if u not able to do contact mechanic
Mar 02, 2015 | Dyson DC41 Animal Vacuum
Same here - but think the switch is the problem
power is the switch and the agitatior is the belt.
Jul 16, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Electrolux powernozzle not working
mine was the power head neck itself the handle got twisted to far and broke the wire a new neck cost 37 bucks online and i installed it myself wires get attached color to color and screw the head back together. it worked just like new!
Mar 18, 2009 | Electrolux Centralux Vacuum
Dyson dc14 power button
I just had this same problem tonight. As I was looking on this sight to find a solution, my husband fixed it. First he removed the extended handle part, then he took the 2 screws out behind the power switch and removed the front cover (directly underneath the power button). He then removed the plastic power switch cover and took the power leads off the switch and removed the switch and tapped on it, then the little button stuck in place:) Sounds silly but it worked! Good luck!
Nov 17, 2008 | Dyson DC14 All floors Bagless Upright...
Power nozzle not working on my vac but does on another vac
Is there a reset button somewhere on the power nozzle? Most of these have a breaker to prevent the motor from burning out.
Feb 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
451 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
