Question about Oster 5834 ExpressBake Bread Maker
Beeper too loud
Is it possible to lower volume of the beeper?
My laptop is incredibly loud. I have the volume at 1 of 100 and it's still extremely loud. Is there a way to lower the volume?
use the fn key and look for the key with the volume labels..if i new the type of laptop you have id tell you what keys
Jun 13, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
Feb 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do you turn the volume down. it's too loud
Main Menu 1. General Setup
1. Mode Timer
2. Paper Type
3. Paper Size
4. Volume
1. Ring
2. Beeper
Jun 04, 2009 | Brother MFC-3240C All-In-One InkJet...
How do I turn off the beepers on my Bosch washer
To turn the beep off (or volume down) on the Exxcel 7 (BOSCH WAE24468GB you do the following:
1. Turn setting dial to off. 2. Turn dial one step clockwise (wait for panel to light) 3. Keep finger on 'RPM' button and turn dial another step clockwise and release finger. 4. The default setting of '2' should appear on the display, this represents the Button Signal Volume 5. Pressing 'Ready in' button cycles through the volume settings from 0 (off) to 4 (very loud!). 6. Turn dial another step clockwise to set the 'Information Signal Volume', which is also set to '2' by default. This is the one that annoys everyone at the end of the cycle!
All the manuals are on the Bosch website, if you know the model code.
Mar 07, 2009 | Bosch Washing Machines
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Beeper is too loud
If you can take good photos of both sides of the board, I can probably show you what resistor to remove.
You could replace that with a trimmer potentiometer I can specify for your from Radio Shack.
Feel free to contact me directly if you'd like.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 06, 2008 | Microwave Ovens
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Oster 5834 ExpressBake Bread Maker Logo
24 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
mike cooper
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
