Question about Audi Vehicle Parts & Accessories
Camshaft sensor location - Audi Vehicle Parts & Accessories
Where is the cam sencer on 2002 mitsubihi montero
Posted on Mar 15, 2014
Where is the camshaft position sensor located on a 2005 cadillac deville base model?
LOCATION
The camshaft position sensor is located on the rear cylinder bank in front of the exhaust camshaft. The camshaft position sensor extends into the rear cylinder head and is sealed with an O-ring.
Nov 10, 2016 | 2005 Cadillac Deville
Location camposition sensorslincolnls3.9
Hi James,i have a 2004 Lincoln LS with the 3.0 engine,mine is Cashmere in color,here's a link to your camshaft sensor. Repair Guides Component Locations Camshaft Position cmp Sensor AutoZone com Here's what they look like,2 of them. Camshaft Position Sensor at AutoZone com Best Camshaft Position Sensor...
Nov 13, 2014 | 2003 Lincoln LS
Where is the camshaft position sensor located in a
The camshaft position sensor is located on top of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the timing belt cover and under the upper radiator hose.
The camshaft position sensor is either located near the top of the engine, passenger-s side, or on the right side of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the camshaft pulley.
This sensor is located at the front of the engine near the camshaft gear this is what I got 6 different locations manual covers 99-05
Oct 10, 2014 | Cars & Trucks
Where is 2003 ford focus camshafts position sensor
The camshaft position (CMP) sensor detects the position of the camshaft. The CMP sensor identifies when piston No. 1 is on its compression stroke. A signal is then sent to the powertrain control module (PCM) and used for synchronizing the firing of sequential fuel injectors. The Coil On Plug (COP) Ignition applications also use the CMP signal to select the proper ignition coil to fire. The input circuit to the PCM is referred to as the CMP input or circuit.
There are two types of CMP sensors: the three pin connector Hall-effect type sensor (Figure 25) and the two pin connector variable reluctance sensor
and next the location of 2003 ford focus camshafts position sensor
Sep 13, 2014 | 2003 Ford Focus
Location of camshaft position sensor on 2009 saturn aura
2.4L cmp sensor exhaust located upper rear of the engine near camshaft cover. 2.4L cmp sensor intake located upper front of the engine near the camshaft cover. the 3.5L cmp sensor located right side of engine compartment above the timing chain cover.below power steering pump.3.6L cmp sensor located right side of the engine near the front and rear.
Sep 26, 2013 | Cars & Trucks
Camshaft position sensor
ON THE 4 CYLINER ENGINE CAMSHAFT SENSOR LOCATED AT THE LEFT DRIVERS SIDE OF THE TIMING COVER. THE V - 6 ENGINES CAMSHAFT POSITION SENSOR LOCATED AT THE FRONT OF ENGINE BLOCK BELOW THE POWER STEERING PUMP.
Aug 28, 2012 | 2000 Oldsmobile Bravada
Where is the camshaft position sensor located on a 2004 dodge stratus 4 cyl 2.4L engine
the camshaft sensor is mounted on the camshaft housing located on the end of the cylinder head.
Jul 08, 2009 | 2004 Dodge Stratus
Need help finding camshaft position sensor
2.0L 2.4L Removal The camshaft position sensor is mounted to the rear of the cylinder head.
Remove the negative battery cable. Disconnect the PCV hose and reposition Disconnect electrical connectors from the camshaft position sensor. Remove camshaft position sensor mounting screws. Remove sensor.Loosen screw attaching target magnet to rear of camshaft and remove magnet.
Instalation The target magnet has locating dowels that fit into machined locating holes in the end of the camshaft.
- Install target magnet in end of camshaft. Tighten mounting screw to 3 Nm (30 in. lbs.) torque. Over torqueing could cause cracks in magnet. If magnet cracks replace it.
- Install camshaft position sensor. Tighten sensor mounting screws to 12.9 Nm (115 in. lbs.) torque.
- Carefully attach electrical connector to camshaft position sensor. Installation at an angle may damage the sensor pins. - Connect the PCV Valve hose. - Connect the negative battery cable.
2.7L V6 Removal
The camshaft position sensor is mounted in the front of the head.
Disconnect electrical connector from sensor. Remove camshaft position sensor screw.
CAM Sensor Location 2.7L
Without pulling on the connector, pull the sensor out of the chain case cover.
Installation - Install sensor in the chain case cover and push sensor in until contact is made with the boss on the head. While holding the sensor in this position,install and tighten the retaining bolt to 12 Nm (105 in. lbs.) torque.
- Attach electrical connector to sensor.
Good luck and hope this helps
May 02, 2009 | Dodge Stratus Cars & Trucks
Vehicle Parts & Accessories Logo
417 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Randy Ohler
Phil Fisher
Level 1 Expert
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
