Question about Electronics - Others
Sandisk sd card problems
Why cant my sd card cant be recognized
SOURCE: MicroSD Card not being read, SanDisk 2GB MicroSD Card
I don't think there is a problem with the card itself. The slot might be dusty. Try and blow into the slot and then blow the card itself.
Posted on Feb 13, 2008
Benimur
  • 6966 Answers
SOURCE: vaio and micro sd
Appreciate the direct "Ask Me".
Since you have verified that the card works (in your phone) and that the adapter works (in another computer), then the issue could very well be with the Sony VAIO VGN-C140G/B. More specifically, the USB ports/drivers. Presumably that the Sandisk 2Gb Micro SD & the adapter were working before and that you are using Windows Vista, pls check your updates that has anything to do with USB. Alternately, you may want to rollback/downgrade the USB drivers and/or seek USB driver update from the Sony site rather from Microsoft.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for your continued patronage of FixYa.
Posted on Sep 13, 2008
SOURCE: My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:http://www.mptrim.com/
  2. To set it as a ringtone, send it as an attachments to you areacodeandyourphonenumber@vzwpix.com. It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Posted on Oct 17, 2008
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
Posted on Oct 29, 2008
  • 3 Answers
SOURCE: Phillips Photo Frame does not recognize SanDisk 1 BG SD card
I used a format program from http://www.sdcard.org/consumers/formatter/eula/
Nether Sandisk nor Phillips tells you the card needs to be formatted FIRST if it is
new and out of the package. It works fine now.......... in the Phillips Photo Frame model 8FF2FPB
If you do not format it first - your PC software WILL NOT even know it is inserted into your device!!
I need no further help on this
Thanks
JohninTexas
Posted on Dec 30, 2008
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
SanDisk 4GB MicroSD HC Memory Card is not recognized by my Sansa
sd utility.exe u download from google it wil dolve u r problem.......
Sep 29, 2009 | SanDisk 4GB microSD High Capacity Memory...
It won't recognize the sd card adapter for mirco
THERE is a tweak with the cards you insert on your picture mate, to be honest these things dont recognize memory cards that are above 2 gig. they also dont recognize some brands. the most compatible as per experience is sandisk
Jun 23, 2009 | Epson PictureMate 500 InkJet Photo Printer
Pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Dec 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Sandisk Adapter Problem in a HP Laptop
If you install SP3 it may work as SP3 updates the index parameters for file size limitations within such an old OS.
Oct 11, 2017 | Electronics - Others
Micro sd card
Does your computer has an internal card reader?
Aug 14, 2008 | SanDisk Sansa E280 MP3 Player
Micro SD card is no longer recognized
make sure the card is 1 gb or less - a Sandisk card would be best since it's a Sandisk player
Jul 26, 2008 | SanDisk Sansa e250 MP3 Player
E400 with Sandisk 256mb + Wi-Fi
Sorry, Sandisk 256mb + Wi-Fi SD Card is not compatible with e400. Only Sandisk Wi-Fi SD Card without additional memory is working.
Sep 11, 2005 | Toshiba e400 Pocket PC
Electronics - Others Logo
35 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
