Question about Compaq Evo N800C Notebook
I go to boot computer up and a bit comes up saying load windoes normally etc so i got to press enter and it loads up with the part of the blue bit going across the screen and then it just blacks out..
Every time i go to turn on my computer in white writing comes up saying start windows normally etc so i pressed start windows normally and it loads up with the bit of the blue bit going across but then everything just stops and goes black and nothing ever comes up even if we wait for ages it just keeps going black and we have tried EEEVEERYTHING!!...any ideas??
  • scarletts May 20, 2009
    Thanks,
    i will wait till stepdad comes back and then see if it works but thankks for the suggestions! :D
    Sniper:
  • 117 Answers
Hello there
This is classic sign of a hard drive problem, you will have to reinstall windows but this is only a temp fix. the best thing to do is to replace the hard drive and reinstall windows. Hard rive are easily and cheaply available on ebay. a 100 GB hard disk will cost you around £20.
Hope This helps. Please don't forget to rate me.
Many Thanks
Posted on May 20, 2009
  • 51 Answers
Press f8 before windows loading use safe mode.
My laptop is Acer and it is showing like "we apologize for the inconvinence, but windows is not starts successfully" and showing some options like safe mode, safe mode with networking, safe mode with...
Here's the step by step on how I fixed this particular problem:
First, boot the computer into safe mode with command prompt. To do this, start the computer, and immediately begin pressing the F8 key at one second intervals. You may have to press several times until the boot menu comes up.
Use your arrow keys to choose Safe Mode with Command Prompt and press enter.
The computer will begin booting. Lots of weird looking white text will scroll by and then the computer will ask you to login or give you a box saying safe mode is running, etc.
Click Ok to finish loading. A black command window will appear with a c: prompt.
At that c: prompt, type chkdsk c:/r and press enter.
Check disk will start to run but then it will say:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y for yes, and press enter. Then reboot the computer into normal mode. Chkdsk will start when Windows begins loading again. Let all 5 phases run and don't use or turn off the computer. (The chkdsk process may take an hour or more to finish.)
Chkdsk finds any corrupted files that are causing the problem and fixes them. Read the results of each phase as it finishes. During the final phase, it will notify you if it finds any corrupted files.
When the Check Disk is done, it will finish loading Windows.
May 05, 2014 | Computers & Internet
Aspire 5710
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Jul 26, 2012 | Acer Aspire 5710 Series Laptop Motherboard...
Primary hard disk failure press f1
Replace the hdd and reinstall windows.
May 22, 2017 | Computers & Internet
My computer is blue screening when i first load it up windows 64 bit home edition gigabyte k8n sli motherboard
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Mar 30, 2011 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
While recovering my laptop 2910tx from recovery cd i got an error 0x4001100200001005. what should i do? install another version os, or other way?/
Since you didn't give much info I'll do my best. Did the error tell you that it couldn't find an operating system? Driver?
Reboot and enter "set up" change the boot order in the BIOS so that your cd/dvd is the first boot device. If you computer isn't destroyed you should get the recovery console then. Try getting into safe mode if possible and doing a system restore, or last known good configuration if you can't restore. If you can boot try those first if not then use the console and try to fix mbr.
MBR stands for Master Boot Record and it's the first sector of your hard drive that basically tells the BIOS where to look for the operating system on your computer.
If, for any reason, the MBR becomes damaged or corrupt, then the operating system will be unable to load. You will normally see error messages like:
Error loading operating system
Missing operating system
Invalid partition table
These messages are definitely not fun, especially if you are not familiar with computers. Most people would automatically assume their computers are dead! However, that's not true. Being in IT myself, these errors are actually preferably to other types of Windows errors. Why?
Well, it's actually fairly easy to fix the Master Boot Record in XP and Vista. All you have to do is load up the Recovery Console and run a simple command. All of your data, applications, settings, etc are still intact on the drive and once the MBR is fixed, the computer will load normally.
So how can you repair your damaged MBR? Here are the steps to follow:
1. First, restart your computer with the Windows XP setup disk in the CD drive.
2. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
3. Once the setup loads, you will see the option to press R to repair a Windows installation.
4. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password.
5. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Note that you may also want to run the fixboot command to repair the boot sector with a new one.
Also, make sure you only use these commands on a system with one operating system installed. If you have more than one operating system installed, fixmbr and fixboot could mess up everything.
Fix MBR in Vista
In Vista (I'm assuming you have Vista) the procedure to fix the master boot record is a bit different. You have to start up Vista in the Recovery Environment and then run the bootrec command. Here's how.
1. First, load up the Windows Vista disc in your drive and press any key to boot from the disc.
2. Choose the language, time, currency, etc and click Next. Now click on Repair Your Computer.
3. Choose the operating system to repair and click Next. When the System Recovery Options dialog comes up, choose the Command Prompt.
4. Now type bootrec.exe and press Enter. This will rebuild the boot configuration data and hopefully fix your problem. You can also run the command with switches to fix just the master boot record (/fixmbr), the boot sector (/fixboot), or rebuild the entire BCD (/rebuildbcd).
Hope this helps.
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | Computers & Internet
Windows xp boots but the desktop will not come on
well there is a couple of thing you could try 1) power on your computer press F8 rapidly and select "last known good configuration" 2) power on your computer press F8 rapidly and select safe mode login with your account and press yes to restore you computer to an earlier time select a date tah the computer worked ok and click on restore
try it and please if you have any problem please comment
Apr 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Windows vista cannot start in normal mode. it keeps flickering between black and blue screens. it can start in safe mode. i have run all diagnostics (chkdsk, scannow, repairs, etc) to no avail
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Feb 15, 2010 | Lenovo ThinkPad T400 PC Notebook
Windows xp quit loading blue screen says page-fault-in-nonpaged-area tech info ***stop:0x00000050(oxc9464269,0x00000000,0x870e208c,0x00000000)
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then press any key.
Then type "y"
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Jan 08, 2010 | Microsoft Windows XP Home Edition
Dell Optiplex GX280 Bluescreen and Hardrive problem
Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
At the command prompt, type chkdsk /r , and then press ENTER.
At the command prompt, type exit , and then press ENTER to restart your computer.
The system should boot back into Windows.
If that doesn't work follow the above steps again but after you type the Administrator password ...
At the command prompt, type fixmbr and continue the next two steps.
THIS SOLUTION IS ONLY FOR A DAMAGED FILE SYSTEM.
Dec 26, 2008 | Dell OptiPlex GX280 PC Desktop
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
