Question about Roper RAS8445KQ Top Load Washer
How do I remove the dial from a roper washer?
Trying to get the spin dial off machine need help
  • steve
    steve May 11, 2010
    Push it in and turn it counter-clockwise.
  • 10,865 Answers
It pulls off but you may need to use a pair of pliers with some tape on the jaws to get it off
Posted on May 20, 2009
How do I remove cabinet from Roper washing machine model # RTW464oyq?
https://www.bing.com/videos/search?q=ROPER+washer+RTW464OYQ+REMOVE+CABINET&view=detail&mid=6FB29920821F644B45B16FB29920821F644B45B1&FORM=VIRE1
Dec 24, 2015 | Roper Washing Machines
How do I fix washer that will not start after I opened door and manually advance to next cycle?
Unplug the machine and replug it - also remove the washing and go through the process again
Jul 23, 2014 | Roper Washing Machines
Washing machine does not spin in any cycle
Hello, It can be one of two things, the contacts in the dial can have worn or broke causing the relay not to open or close to activate spin cycle.
Most likely it is your transmission or main gear for your spin cycle.
I hope its the dial which is an easy fix, but the trans is a big project IF the washer is worth it. You may consider looking for new/used washer if trans is bad. Good Luck.
Dec 11, 2012 | Roper Washing Machines
Where is the reset button on Roper washing machine top load water fills but nothing else happens
try to turn the timer dial to rinse and spin, and then see if the water will drain
Jul 07, 2011 | Roper RAS8445KQ Top Load Washer
Bought used roper washer. worked for first load and now wont work. washes and then the dial satys in same place. Wont empty or spin, nothing.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Roper RAS8445KQ Top Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
NOT SPINING ALL THE TIME, could it be clutch?farrulla@yahoo.com
if you have to reset the dial, it would be a worn out contact in the time.
purchase a rebuilt timer and all should be ok
if there is an issue with the clutch you will smell a burning smell as your clutch heats up from slipping.
i dont think it is the clutch, but more likely the timer. and possibly the lid swith
May 26, 2009 | Roper RAS8244KQ Top Load Washer
I have a roper that spins but want drain
Your drain pump is clogged.
Remove the cabinet, remove the pump and remove whatever is clogging the pump.
The pump is located in front of the drive motor.
Mar 03, 2009 | Roper RAK2751WWH Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
61 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
