Slow computer How much memory would I need for a 160gig internal hard drive to work efficiently. I have 1gig. My computer is slow.Do you think I would need at least 2gig to work faster.
    Novelist:
  • 288 Answers
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.
After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Posted on Jan 01, 2014
  • tom170177
    tom170177 Aug 28, 2014
    You ribbon conections are oxidized. Get some CRC electronics cleaner at the auto store. Open up the computer and spray all the ribbon connections, try to reincert them a couple of times. Worked for me I was about the junk my PC. Fast as can be now, good luck
listeur
  • 88 Answers
SOURCE: How to move contents from computer default hard drive to external iOmega hard drive, to make computer faster
There is a program on the xp cd called Fastwiz- it will save all your profile data for you. Unfortunately it's REALLY slow and you would be better doing it by hand. If you want to do it by hand you will need to copy all the data in the Documents and settings folder for all the profiles, plus any other data that you will need to reload the drivers. I recommend saving the e-machines drivers directory.
Wiping and reloading the operating system is the best way to resolve problems with a slow system, and a faster bigger newer hard drive is a good idea too. E-machines have a tendency to just die after a year- be aware that you get what you pay for. Also adding more ram to this system will help too.
Posted on Dec 02, 2007
preachw996
  • 1179 Answers
SOURCE: hard disk is very much SLOW
Click on your Windows start menu. Select Control Panel>Performance and maintenance. Run the Disk cleanup utility. Run the Disk Defragmenter. When all these steps are complete reboot. Your hdd should run faster. Hope this helps & please take a moment to rate this solution. Thanks.
Posted on Mar 19, 2009
geraldo14200
  • 48 Answers
SOURCE: Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Posted on Apr 06, 2009
Crankstart
  • 696 Answers
SOURCE: mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Posted on Aug 19, 2009
  • 31 Answers
SOURCE: slow hard drive
you might a bad file on there like a virus or spam were does anything pop when plugged other than saying its connected
Posted on Dec 09, 2009
How to fix a slow Mac? My MacBook is getting slow recently, how to speed up it?
there are many reasons about why your Mac works slowly. you should firstly clean it up. here is article which talks about how to speed a Mac you may need: 11 Methods to Speed up Your Mac
Jun 25, 2015 | Apple MacBook Air
Laptop runs very slow asus
FIXING A SLOW COMPUTER
A slow computer could be caused by a number of things -
1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM.
2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc.
3. Uninstall/remove unused programs, this will also free up hard disk space.
4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it.
5. Install latest Windows updates.
6. Update virus definition files and scan computer for viruses, Trojans, malware etc.
7. Clear the Internet cache for faster browsing.
8. Hard disk maintenance is required at least once a month to keep it functioning efficiently.
Run the following programs -
Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space.
Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
May 12, 2013 | ASUS Computers & Internet
My laptop is very slow and lags
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY.
Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Mar 05, 2013 | HP Mini Computers & Internet
My computers are extremely slow
Dec 29, 2012 | HP Computers & Internet
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
My Inspiron 2200 used to run fine; now it is ridiculously slow, which I think started after I updated everything after about six months our out of use. It's especially slow opening a browser and...
There a few things that slow your computer the way you described.
  1. You need memory on the hard drive that your Operating system is on. I would say 25% or more.
  2. Clear your temporary Internet,cookies and cache from you web browser (IE, FireFox, Opera, Ect)
  3. To many thing running in the background, if you are comfortable with computers (you can use "msconfig" to turn extra programs off)
  4. Defrag your hard drives
  5. As much memory as you can will always help.
I hope this helps.
Jan 22, 2010 | Dell Inspiron 2200 Notebook
Computer is very slow websurfing, would changing the hard-drive from 100 gb to 320gb help alot with this, and if so, will I loose all my stored info?
you can check to see how much free space you have on your 100 gb drive ... just right click on the C: drive icon .. and then select "properties" .. if you have lots of space left then thats not your problem and a new 320 gb wont help .. if you see that you are running out of space (like less than 10 or 20 gb) then it will help .. you can transfer or ghost your entire drive over to the new drive if you have the proper equipment .. or if you take it somewhere to have it done .. you may have to reregister your operating system but that only takes a phone call or an internet click .. much more likely your computer is full of spy and ad-ware unless you have a good security suit that takes care of that sort of stuff ... if you dont have any anti spy-ware program then "spybot search and destroy" is a good start and its free ... some anti virus programs can really slow a computer down .. if you have a good one stick with it .. if you dont then AVAST or AVG are really good and free ... if you havent done so you can "clean up your hard drive" .. that includes getting rid of temporary file clutter and defragging the hard drive ..you should do that every couple of months or schedule it to happen at set intervals .. check how much memory you have .. most computers today should have 1gig or more memory .. if you have only 256 or 500 meg then things will run slow .. depending on what your operating system is .. XP will work ok on 500meg Vista wont .. ...both can benifit form increased memory ..
Nov 22, 2009 | Sony VAIO VGN-FE550G Notebook
I upgraded the memory from 1Gb to 2 Gb but my laptop's still slow
it can't be, check if the windows is reading 2gb from system under control panel.
to find out if your pc is fast, see if it plays a game faster than before or use a program faster than before
there is no diffrence in using windows itself. example i think in your mind you'd expect to click on my documents and it loads it super fast now with 2gb of ram? no, you're wrong weather you have 1gig or 2gig windows still works the same
the diffrence is Faster file transfer, faster applictions but not a faster windows.
it could also be the norton if you installed, it lowers your speed.
check Task manager, in the performance section
cpu usage should be under 10%
and pf under 500mb
Mar 03, 2009 | Toshiba Satellite M55-S3512 Notebook
Computer running slow
Slow with programs or slow online?
Try holding ctrl+alt+del and click on the performance tab to see how much available memory you have.
You possibly could be infected. Try AVG free virus software. It finds them when others dont.
Dec 10, 2008 | MSI KM4M-L Motherboard
PC memory issues
If you're working with photo files, there's probably no piece of hardware that will speed up the process more than lots of RAM. Anything beyond 128MB will dramatically streamline your workflow. Image-processing programs like HP Image Zone need much more RAM to work efficiently with large files. But the slow speed may be due to another culprit: fragmented hard drive files. If you have problems with speed when opening or closing a file, perhaps your image data is scattered all over your drive. The result? Your hard drive is spending all its time and energy gathering the data to feed your applications. Defragmenting the drive is the simple solution to tidying up your files. If the files aren't fragmented and more RAM doesn't do the trick, your hard drive may just be slow. Consider replacing it or adding a second, faster one to your system.
Sep 08, 2005 | HP Photosmart 945 Digital Camera
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
