Question about Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower
Hour meter not working - Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower
If one pumps water from a source at a rate of 7 cusecs cubic meter per second, how many cubic meters of water would be pumped in 24 hours?
7 cubic meters /second = 7 X 60 /minute
= 7 X 60 X 60 / hour= 7 X 60 X 60 X 24= cubic meters per 24 hours or another way
7 X 86400 = cubic meters per 24 hours
May 26, 2017 | In Office Equipment & Supplies
Hi how to convert to kilowatt hour using this meter? Do we really need to multiply by 20
Yes, you do have do multiply, but not the number on the dial itself. This is a commercial or heavy residential use meter. They are geared so that each kilowatt hour measured by the dial is actually 20 kilowatt hours. This is done since some users use so much power that the meter could actually roll over during a normal billing cycle using a regular meter. So, if you are reading this meter to determine how many kilowatt hours you have used since the last reading, you simply read the meter as you would any normal meter to get the number displayed. Your photo reads 13525. That is your current meter value. If you last bill stated the meter value was 13501, that would indicate that you used 24 (13525-13501) times 20 or 480 kilowatt hours since the last bill.
Hope this helps!
Aug 15, 2016 | Office Equipment & Supplies
Caterpilla backhoe 420D hour meter not working
Go to this link, search the forums for help with 420 cat hour meter. It is probably a simple fix even if you have to replace the unit. Join the forum for free, and ask your question in the tractor-backhoe forum. THANK any one who offers assistance and let the forum know what you finally did to fix the problem so WE CAN ALL benefit from your experience! There are many wise operators,owners, and mechanics on this site.
Mar 28, 2014 | Caterpillar Backhoe Tractor
Reset hour meter
  • If it is a digital hour meter i am afraid you are out of luck.If it is anolog you can remove it and then open the meter then you need to rotate the numbers foward until you roll the numbers back around to zero. this takes a very long time but can be done. Your final option is to buy a new hour meter and set it from zero. An hour meter is the same as a car odometer they are not ment to be fooled with.
Jul 09, 2013 | Garden
535 on hour meter
if the key was left on the hour meter will keep running
Sep 07, 2012 | Garden
How to reset hour meter on encore mower
As far as i know there is no re set for the service minder/hour meter, it will be a replacement.
Jun 09, 2012 | Garden
John Deere 4610 compact tractor hour meter not displaying hours
Check your fuse panel. Check if you voltage it. Replace meter last.
Apr 14, 2012 | Garden
Operating manual for bw 30 & bg 30 timer counter
1) Identify product on following page:
http://www.hugo-mueller.de/elapsed-time-counters/mueller-bw-30-bg-30,p,en,8,34.html
2) Sales sheet shows model numbers and voltages and shows that product is hour meter:
BW30 is AC alternating current with choices 230Vac 115Vac or 24Vac
BG30 is DC direct current 12-48VDC
http://www.hugo-mueller.de/download/34_DB_BW30_BG30_BW22_GB.pdf
3) Hour meters normally have 2 terminals, but there is not a photograph of back of product.
Hoping you will photograph your product and post image on your website and add a comment to this thread with web address of image, along with other information you have.
4) Usual set up for timers and counters: terminal 1 is for black wire L or L1, and terminal 2 is for white wire N or L2.
If terminals are not labeled, then wires can be connected either way, but as you face terminals, terminal 1 is on left.
5) Wiring:
Hour meters are wired in parallel, not series.
For example hour meter on 240V pump: 2 wires go to pump.
Simply connect each hour meter terminal to one of the wires.
Another way to illustrate: If you test electricity using two-prong tester, you touch each tester lead to one of the wires. Hour meter connects same way.
6) How hour meters work:
Hour meters count number of hours electricity is turned on.
For example I have 240V Grasslin hour meter connected to water well pump.
Water well has pressure switch that turns pump on-off.
If hour meter is connected before pressure switch, then meter simply runs continually since it receives power all the time.
So hour meter has to be connected after the pressure switch. And then meter counts only when power is turned on to well pump. This way I see how many hours my pump runs and then estimate pump cost by multiplying hours x pump wattage.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 14, 2011 | Miller Electric Manufacturing Miller...
Can I add an hour meter to my Crafstman 917.289340 lawn tractor with the 22 HP Kohler engine? Found a part #401763 for a different model Craftsman. Will it work?
Yes, you need to find a wire that is hot (12vdc) when the engine is running, tap into this wire and hook to the positive side of the hour meter and the other will be a ground. This will keep track of engine hours only. If you want complete total hours, any hot wire with the switch on will work.
Feb 27, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower Logo
59 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
