Question about Line 6 Music
My line 6 spider 3 turns on but has no sound - Line 6 Music
paulm10
  • 73 Answers
SOURCE: line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Posted on Jul 09, 2009
djlaplaya
  • 74 Answers
SOURCE: en los amplificadores line 6 spider iii
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Posted on May 06, 2010
  • 5603 Answers
SOURCE: My Line 6 Spider Amp sound goes out when I plug in
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
Posted on May 07, 2010
  • 5603 Answers
SOURCE: when i turn on my line 6 spider 3 amp it keeps
MOST likely the power amp chip is blown. They use a TDA2050 chip that is in a seven lead power tab package similar to the TO220 transistor package. Readily available from DigiKey.com for just under $3.
If you keep replacing the fuse, you may damage other components.
The other possibilty is a diode and/or filter capacitor has shorted.
Posted on Jul 17, 2010
  • 5603 Answers
SOURCE: Line 6 spider ii. As soon as I turn on the power I
Not a transformer problem... this is likely filter capacitors, rectifiers, and PROBABLY a bad amp chip. Service this before it wrecks the speaker.
Posted on Aug 10, 2010
Need schematic for line 6 spider 4 30 watt l
If you read down almost to the bottom of this link, you'll find a working link to it.
Thread LIne 6 Spider IV 30 Schematic request
Mar 13, 2016 | Line 6 Line6 Spider IV 30
How to reset line 6 spider 3 15 watts
Turn the amp off. Hold down the A (or clean) button as you turn on the power and hold the button for 5-8 seconds, then release.
Jan 25, 2014 | Line 6 Spider Iii 15 Modeling Guitar...
I have a line 6 spider jam ...was playing guitar and then the sound went dead... loops work lights work but no sound
It probably the output Ic named TDA7293 and maybe because of the fan malfunction, let me know a bit further to help you more.
Oct 22, 2013 | Line 6 Spider Iii 75 Guitar Combo...
My line 6 spider 3 75W amp will not show any lights when I turn it on nor make a sound. Only the backlight on the display will turn on and be blank. I have tried the factory reset and it still will not...
Probably the 3.3 volt power that supplies the DSP has failed or is being shorted out. If you are not electronicaally adept, best to take it to a shop for repair.
Jan 02, 2011 | Line 6 Spider Iii 75 Guitar Combo...
Line 6 spider ii. As soon as I turn on the power I get a huming sound. can not adjust anything. The only sound is the hum. Could it be a transformer problem! much appreciated
Jul 18, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
When i turn on my line 6 spider 3 amp it keeps blowing the fuse
Jul 17, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
Jan 23, 2010 | Line 6 Spider Iii 30
Line 6 spider III 15 watt sound problems
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
Top Line 6 Music Experts
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Line 6 Music Expert? Answer questions, earn points and help others
