SOURCE: mer5755qab oven takes an hour to heat to 200
Either your bake element is bad or there is a bad connection going to the element. This is a very high current connection so bad connections are always a possiblity. Also check and make sure your broil element is working as some ovens use it for pre-heat. Do both elements seem about the same temp? You can turn the oven on and carefully hold your hand a few inches from the element to see if they are getting equally hot. If your connections are good to the elements then one of the "calrod" elements is probably bad. You can also check the resistance of each element. Not sure of exact reading but a higher resistance means less current going to the element. Just compare reading on each one and go from there. Good luck!
SOURCE: stovetop works but oven does not.
Most likely your problem is the glowplug aka oven igniter. Even though it comes on it must reach a certain temp for the gas to come on. Occaisionally the valve will be bad but 90% of the time it is the igniter. Part number is 74007498
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
