Question about Sunbeam California King Heated Electric Mattress Pad 250 Thread
I read the washing intructions and followed the label, Now my blanket if flashing and I have tried all the steps I have read on the internet.
Can this blanket be washed?
Yes, but follow these instructions. In particular, do not immerse the temperature control switch , which has to be removed from the blanket. If it is permanently attached, then hand washing only is possible.
http://www.sunbeam.com/garment-care/care-and-cleaning/care-and-cleaning.html
http://www.howtocleanstuff.net/how-to-wash-an-electric-blanket/
Dec 03, 2015 | Sunbeam Electric Blanket - queen
Why does the light keep flashing red on my sunbeam electric blanket control remote? It just keeps flashing on high I try ed unplugging from the outline and the blanket nothing works. It started doing this...
There is a problem with the blanket. Since it started doing this just after washing (as per instructions), I suspect that somehow - running it thru the washer caused the problem.
Since it is an electrical device, if allowing to air dry thoroughly doesn't let it work as expected, you should stop powering it - and use it only as a non-powered blanket or discard and replace.
Feb 03, 2015 | Miscellaneous
E on controlls
If you have a digital control, it is designed to flash "E" on the display to notify you that a problem may have been discovered. Gradient controls and warming throw controls use a blinking indicator light for this purpose.
Follow the instructions on the flag tag to reset the control or follow the steps below.
  • Unplug the system from wall outlet.
  • Check that the control is well connected to the module.
  • Plug the power cord into the wall outlet.
  • Set the control to "on".
If the system still does not operate, disconnect the power cord and contact sunbeam
Sites sunbeam Site
Jan 11, 2015 | Sunbeam Twin Heated Blanket Navy Blue...
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
Sunbeam electric blanket repair waynesboro ms
wash the blanket then throw it in the bin
water and electrical components do not mix
electrical blankets are just a resistor element in ceramic covering and if you put that in a washing machine that is the end of the insulation
Mar 18, 2017 | Sunbeam California King Arlington Heated...
How to insert symbols to flash drive label?
There is a method to do it. But not simple. But following few steps you can do it.
Visit SmartUSB.net.
It explains step by step, how to insert symbols to flash drive label.
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
I think you will also like these things,
Change your flash drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Jul 25, 2012 | Computers & Internet
Our door latch broke (the one inside the face of the washer, not on the door) when the washer was spinning a heavy wet blanket that got out of balance. We have the new part in hand from Maytag parts. How...
The following link explains step-by-step how to replace a door latch on a Whirlpool Duet:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Read through the information I provided and let me know if you have any questions. An alternate method is to remove the washer top panel and work down through the top of the washer. Access can be a problem sometimes, however. I hope this helps you.
Nov 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My PC internet connection is disconnected after 2-3 minute.
Here's some steps that worked for me in instalilng Flash player:
Please follow the steps below for uninstalling and reinstalling Flash player:
a. Download the most recent Flash Player uninstaller to your desktop from the TechNote below. Please read the instructions in the TechNote before running the uninstaller.
How to uninstall the Adobe Flash Player plug-in and ActiveX control
http://www.adobe.com/go/tn_14157
b. Quit ALL running applications, including all Internet Explorer windows, other browser windows, AOL Instant Messenger, Yahoo Messenger, MSN Messenger or other messengers. Check the Windows system tray carefully to make certain no applications which might possibly use Flash Player is still in memory.
c. Open the following folder: C:\WINDOWS\system32\Macromed\Flash
d. Run Flash Player uninstaller.
e. Check if there are files left in the folder: C:\WINDOWS\system32\Macromed\Flash. If there are any files left inside the folder, delete the files.
f. Download and install the latest Flash player at:
Flash Player 10,0,12,36 Active X (for Internet explorer)
http://tinyurl.com/67twte
Flash Player 10,0,12,36 Plug-In (for Firefox,Netscape,Safari,Chrome,etc)
http://tinyurl.com/8nz9s
Jan 29, 2009 | Macromedia Studio MX 2004
Sunbeam California King Heated Electric Mattress Pad 250 Thread Logo
Top Sunbeam Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Sunbeam Furniture Expert? Answer questions, earn points and help others
