How to clean ewf 85661 - Washing Machines
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
How to clear the cmos on motherboard ga 85661 fxmp-rz
google the above...How to clear cmos.
all motherboards, all computers are the same
Jul 19, 2014 | Computers & Internet
Electrolux EWF 1282 start pause button is flashing wont start a load have reset it no error messages came up have also cleaned the drain filter the manual way underneath the machine still nothing any
Hello terry_gwen - Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. I understand that the filter has been cleaned, however, if you noticed a humming noise, it could either be a clogged drainage hose, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Apr 14, 2013 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Electrolux ewf 1470 not spinning no error message
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly.
Oct 07, 2012 | Electrolux EW1000i Front Load Washer
Ewf 1087 error 4h
Hello - Are you certain the error code is E4H? This manufacturer does not have any E4H error code for any washer or other units. They do have E4A and E5A codes however.
Sep 17, 2012 | Electrolux Washing Machines
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
Whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Mar 12, 2009 | Electrolux AWF1235 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
