Question about Kenmore Sewing Machines
Kenmore sewing machine 385 1249380
I have an older Kenmore 10 Stitch Sewing Machine. Model 385 1249380. Trying to get the tension settings for short straight stitch, and also would like to know what the stitch dial should be set to... to get this stitch... as it has several different colors on the stitch setting knob. thank you
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
  • 255 Answers
SOURCE: I have a Kenmore sewing machine Model 158.17030.
Hi. First, I'd recommend you get a replacement manual. They are really useful. Check out http://sewingpartsonline.com/sewing-machine-instruction-manuals.aspx.
I assume you have different stitches on the machine and a diagram of some sort showing what each stitch looks like. Find one that looks like:
---^---^---^--- (maybe on its side). That's the blindstitch. Some machines require you use a blindstitch foot with the stitch, but some don't. Without the user's manual, it's hard to say what your machine requires.
Good luck and let me know what happens.
Robbie
Posted on Jan 12, 2010
  • 35 Answers
SOURCE: My Kenmore sewing machine model number is 17630,
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Posted on Nov 27, 2010
Haven't used my Kenmore sewing machine #385.19153 for a long time. The display shows "bobbin winding" I don't remember how to change for simple straight line stich
Try pushing the bobbin winder spindle to the left. It's on the top of the machine to the right of the spool. When this spindle is pushed to the right, the sewing machine is ready to wind a bobbin. Once the spindle is to the left, you should be able to select a straight stitch (stitches 10-12), set the stitch length and check the thread tension.
See https://www.manualslib.com/manual/505279/Kenmore-385-19153.html?page=44#manual for a picture.
I hope this helps.
Jul 04, 2017 | Kenmore Sewing Machines
Is the Kenmore sewing machine 15343 able to do a baste stitch? If so, how?
A baste stitch is basically setting the machine to a straight stitch with the longest stitch length available. Loosen the top tension slightly if you want to remove the basting later.
May 12, 2017 | Kenmore Sewing Machines
I have a kenmore model#385.19153690 sewing machine. I cant seem to get a long stitch going forward, only when I go backwards can I get a long stitch. So I'm stuck with a short stitch when sewing forwa
Given this is a computerized machine, it may well be it needs a repair shop.. it's not just a matter of adjusting a knob.
Do you have the manual ? If not, I'd try to find one.. many sites online sell copies of manuals for a lot of machines, well worth a google search. If it's simply not doing what you have set it to do, then repair is likely going to have to be professional.
Nov 18, 2014 | Kenmore Sewing Machines
Tension setting for small straight stitch on a Kenmore 10 Stich model 385 1249380 sewing machine.
Please go to Kenmore model 385 1249380 sewing machine sell shop and ask the machanic or shopkeeper.
Jan 01, 2014 | Sewing Machines
Kenmore 1941 sewing machine irregular stitches
try rethreading the machine top & bobbin make sure to get ever thread guide
try chaning to needle, make sure the needle goes all the way into the needle holder-normally flat side goes to the back of the machine
check to make the thread is moving smoothly around the tension dial
if these suggestion don't help, then the machine probably could use a servicing
Mar 13, 2012 | Sewing Machines
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Jan 14, 2010 | Kenmore Sewing Machines
Birds nests under fabric and thread breaking.
My manual says the needle thread tension is too loose , OR the needle is to fine/heavy for the thread being used.
Jan 24, 2009 | Kenmore 19001
Tension problem using zigzag stitch
Most likely the fabric is too light weight to sustain the thread tension using a wide zig-zag stitch. Tunneling will occur in this case.
Loosening the tension (top & bobbin) could also be beneficial.
Sometimes the machine has a special foot (sometimes called overlock) that will help. However, using something to add more body to the fabric, like a wash-away or tear-away fabric stabilizer to the seam or even adding paper will help limit tunneling. Sometimes heavy starch applied to the seamline before stitching will be helpful.
tunneling when zigzagging Threads Magazine Gatherings Forum Sewing...
zigzag stitch troubleshoot
May 08, 2017 | Kenmore 19233 Computerized Sewing Machine
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
