Question about Dryers
Where is the filter/hose supposed to go??????
I've been given an old Creda tumble dryer model No 37305, it's a bit battered but apparently works fine but I've no idea how or if it should have a hose or a filter fitted to it. I thought dryers were supposed to have a hose to vent any hot air and something to catch the fluff but this seems not to have one. Does something fit on to the door? There are gaps in the door so I'm thinking maybe something actually fits to the front of the door and collects the fluff and vents out the air???? Please help as I am most confused
  • songbirdsdes May 20, 2009
    Hi, thanks for the help.
    I've looked underneath but there is nothing at all, nor on the sides. At closer inspection it seems as if something should definitely attach to the front of the door, a bit like a cars hubcap. I'll just have to search Ebay etc for something that looks right I think.
    Thanks again.
    President:
  • 1,136 Answers
Hi. Is there a 4" jole that the vent could go in underneath the dryer? Some older model were set up that way. I have never heard of this brand but, it's an idea. Some models were set up to vent out the sides too.
Posted on May 20, 2009
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
My creda reverseair tumberledryer won';t work. my
Hi
If you can hear the motor running and have also checked the belt tension and they are O.K., then the only thing I can think of is the Motor pulley, where the belt sits on.
Check that out and make sure it is not loose on the motor shaft, so that the motor turns but the pulley slips.
Regards
Ash
Nov 09, 2009 | Creda IWD12 Front Load Washer / Dryer
Creda dryer thermostat failed
you have an air flow problem
Aug 17, 2009 | Dryers
How to fit a belt to a creda tumble dryer
open case
loop belt around bits
close case
more particularly
Unplug dryer
pull dryer away from wall
remove 1 screw each side at back of top plate
slide top plate backwards and lift off
undo 1 screw each side of front kickplate
tlit front panel up
unplug door switch
set front panel aside
careful of control panel its V.fragile
(I lay the dryer on its back)
pull out old belt and bits of belt
loop new belt round drum at wear marks
pull tensioner to end of travel against spring
loop belt round motor pulley & both tensioner wheels(most creda) 1 wheel (old)
relax tensioner
rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
creda uses hotpoint parts
Oct 30, 2008 | Dryers
Dryers Logo
70 people viewed this question
Top Dryers Experts
