Question about Quality Pine Waterbed Pedestal Pine Riser Base
Pedastal corner brackets
Have lost the brackets and can not find them. Where can I buy some corner brackets?
Brand new tub vibrates so bad i have to turn it off very unhappy
have you removed the shipping bolts on the back of the machine and make sure it is level and all the legs are locked.if it is attached to a pedastal then make sure that it is properly secured to the pedastal.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a pedastal singing machine that is missing the power cord. Where can i get a replacement?
Nov 08, 2010 | Audio Players & Recorders
How many bolts hold the pedastal to the block on a 1996 f350 turbo charger
there is a total of 4 bolt holding the pedastal to the block and two bolts holding the turbo to thepedastal
Mar 28, 2010 | Ford F-350 Cars & Trucks
I just wanted to know what pedastals will fit with the kenmore washer 48102
BEFORE U BUY PEDESTALS PLZ GIVE THEM MODEL NUMBER AND THEY WILL LET YOU KNOW WHAT WILL FIT THANK YOU
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Missing LG pedastal
You can find a replacement base stand assembly for that model (42LC7D) at the following link:
LG 42LC7D Replacement Part Base Stand Assembly
Model # RU52SZ30 may have no stand / pedestal available.
Nov 17, 2008 | LG RU52SZ30 52" Television
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Attach pedastal to whirpool duet washing machine front loader
you will want to lay the duet unit on its back. remove the legs. put the base up to the bottom of the duet. you can use the legs as bolts and pass them thru the top of the base back into the bottom of the duet appliance, using them as bolts. I have had some people just get new bolts. this should fix you up. please rate this if it was any help.
Thanks,
David
Oct 11, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Missing key
Once back inside the temple, the first three floors will be basically the same,
with a few minor exceptions. When you get to B1, head up to the switch you
went to the first time, but instead of hitting it, bomb the rocks to the left
for a shortcut to the key. Grab it and run to the door, saving you a lot of
time.
For the second floor of the temple, you will still need to hit the two switches
to drop the key down, but instead of pulling the lever behind the Phantom, you
can bomb the wall directly south of the entrance for another shortcut. Grab
the key, then proceed the same way as the first time, through the blue and red
blocks. Head for the locked door, but this time stop at the safe zone for a
bit, and head just west of there and bomb the wall, revealing a 30 second bonus
to your Hourglass. Then you may proceed downstairs.
The third floor follows an almost identical procedure as the previous run.
First, grab the Force Shard in the northwest corner and take it to the
pedastal. Once that's taken care of, head east and bomb the rocks for an
additional 30 seconds. Then, head just south and use the Boomerang to hit the
switch, stopping the nearby spikes. Then, head to the southeast corner, grab
the second Force Shard and return to the pedastal. Now, instead of going to
hit the switch to lower the fires, you can use the shovel to reveal a rising
wind that will carry you to the top platform so that you can get the key.
Kill the Phantom, grab the key, and head to the locked door. Grab the last
Force Shard and return it to its pedastal, then proceed through to the next
room. Run to the far left side of the room, grab the 30 seconds, then head
back to the Door of Wisdom and proceed through and down the stairs.
Jan 23, 2008 | Nintendo DS Lite Console
Quality Pine Waterbed Pedestal Pine Riser Base Logo
393 people viewed this question
Top Quality Pine Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Quality Pine Furniture Expert? Answer questions, earn points and help others
