Venturer tv codes
Codes to set up a universal remote
SOURCE: ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
Posted on Dec 07, 2007
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
Posted on Apr 02, 2008
IrishDruid
  • 2712 Answers
SOURCE: REMOTE CONTROL SET UP CODE
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Code search for Panasonic Tv on Universal remote
i need code for panasonic tv with zenith remote control
Posted on Aug 27, 2008
SOURCE: venturer universal remote code
The code I used is 0449...I have a STS20-S Venturer Home theater
Posted on Dec 04, 2008
Universal remote control codes for a venturer TV/ DVD combo
Applicable code(s) would be in a compatible universal remote control. All universal remote controls do not contain all possible codes.
Sep 17, 2017 | Universal Remote Control Televison & Video
How do i program a venturer tv to a universal remote
You have this backwards, codes are in the remote. You can use its code search feature to find something that can manage some or all functions of your Venturer TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Oct 23, 2016 | Televison & Video
Have an exact remote replacement for venturer plv16100 Tv. How do I get it to work with my set?
To select a proper universal remote control, you should know about the number of digits to its set-up codes.There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices.After confirming this, check the sites linked here.Both the sites have set-up code list and set-up procedure to many popular brand remote controls.Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brandyou have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack.Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/Check this site too.http://remotesearch.blogspot.com/Universal remote controls are available at most of the electronic spare part selling shops.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Feb 25, 2015 | Venturer Televison & Video
Venturer LCD TV, 17", how do I change the size on the picture manuelly by hand on controls on the TV ?
You should have a remote control to select its aspect ratio. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Jan 15, 2015 | Venturer Televison & Video
How to find code for universal (ge)remote for my venturer 19"tv/dvd combo sn/la121bd040694 plv97187h
If you have universal GE remote, you can use its "code search" function to find a suitable code for your Venturer TV. A search through all the codes stored in the remote may not work, in which case you will have to try another universal remote.
Oct 18, 2014 | Venturer PLV97187H 19"" Class 720p LED LCD...
Need codes to program remote
most universal remotes have a auto program mode or coad if you can't find a coad to match your brand
Apr 27, 2009 | Televison & Video
Tv codes for a rca universal remote controller
Programminng an RCA remote cotroller for a Toshiba ,CE19H15 model
Jan 25, 2009 | Televison & Video
Venturer universal remote code
Nov 27, 2007 | Venturer (1012827) System
Televison & Video Logo
Top Televison & Video Experts
