Question about American Standard Home
My American Standard R120 shower valve has excellent pressure on the cold side, no pressure on the hot side.
I have enough pressure on the cold side to get water to come out of the shower head. On the hot side there is not enough pressure to get the shower head to work.
    Problem Solver:
  • 12 Answers
Could be a chunk of scale in the valve. Need to turn off water supply and take valve apart. If nothing is found, turn water supply on to give line a 'quick' flush and turn back off. If this does not help, you probably have an obstruction somewhere in the hot supply line and a plumber may be needed unless you are handy. Good luck.
Posted on Jan 01, 2014
4 Suggested Answers
  • 374 Answers
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Posted on Oct 21, 2008
  • 14 Answers
SOURCE: moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Posted on Dec 27, 2008
jeff_drakesr
  • 155 Answers
SOURCE: no cold water from Moen 2253 tub/shower valve,
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Posted on Apr 05, 2010
No hot water pressure
These types faucets have a what is called an anti scald valve build into them, it is required by law, it is either defective or out of adjustment, contact a local hardware store for more detailed info.
Feb 02, 2012 | American Standard Plumbing
Ever since I had This American Standard Williamburg shower control valve I get a terrible water hammer at comfort tempetures. My friend the plumber who installed it pulled the Pressure balance valve out...
NO DONT replace anything > You have what id call water hammer. This happends when water gets in the air chambers, Air chambers are nothing more than a 1 foot or 2 foot long section of pipe with a cap on it. When its working air gets trapped in the pipe and you can compress air but not water, so if the air is gone BANG BANG goes the pipe.
takes 10 mins to fix. turn off the water to the house out side. open every faucet in the house and the hose fauects out side. wait 5 mins and then close everything and turn on the water. You will see ait come out of the faucets it will stop after just a momnet or two.
That should do it. check your tub shower valve and it will work fine
Thanks for asking us to help
Hope this worked for you Tom
Sep 16, 2011 | American Standard R120 Pressure-Balance...
R120 Valve I have good pressure with the cold water but no pressure with hot water
I imagine you have the installation instructions since you just installed it. Your new shower handle has a hot limit safety stop. You can set this with a flat blade screwdriver. The safety stop is the red ring in the handle and all you need to do is pry the ring forward with the screw driver and rotate it clockwise to increase your hot water.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | American Standard R120 Pressure-Balance...
I have a one handle shower/tub faucet, and when you run straight hot water (to preheat for example) the water shuts itself off. Lever is still in the lifted/on position however. Cold is fine, even warm...
If this is a newer valve what is probably happening is the valve is a scald guard valve and is shuting itself off when it senses no pressure on the cold side. I don't have a lot of experience with am. std. valves but I'm sure you can get instruction on line to set heat setting on valve higher. Thank you.
Jan 20, 2011 | American Standard One Handle Tub & Shower...
Water will not flow through on american standard with pressure balance. Some hot water came out with low pressure then stopped and now nothing will flow.
I just spent a week wrestling with a similar problem, and I'm posting in an attempt to save someone else an ulcer. Using a Colony single-handle valve, the temperature got so we couldn't control it. Either all hot or all cold. I called A.S. and they sent a new pressure balancing cartridge and new valve cartridge. Replaced both and then there was no water at all coming out of the shower head. Tried every possible combination of old and new parts, flushed pipes, etc. Finally took the shower head off and found it completely clogged with debris. It was a mix of sediment and the white grease that was in the new cartridges, which must have been displaced when I started messing with it. And it clogged it all at once (no flow problems before all of this). Works fine now!
Jan 02, 2011 | American Standard One Handle Shower Only...
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Not enough hot water in the shower even if I turn the handle all
Your valve has an anti-scald feature which automatically adjusts the water temp if cold water is diverted to another location, e.g., a flushed toilet, washing machine filling, etc. Most valves have an adjustment screw to allow you to set the temp. Since each manufacturer is different you'll need the manual or contact the manufacturers support. BTW, these anti-scald valves are being added to building codes in many parts of the U.S.
Mar 07, 2010 | American Standard Cambridge 5' Americast...
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
Home Logo
120 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
