Question about Weber Genesis Gold B Grill
I have a 3week old Webber Q220 bbq and it does not ignite - Plenty of gas but igniter does not work - what to do please?
When we turn on the gas we can hear it but when we push the iugnitor button nothing happens
  • 494 Answers
If it's no longer sparking, then it sounds like your igniter battery is dead. Unscrew the igniter button and replace the battery.
Posted on May 31, 2014
4 Suggested Answers
  • 2557 Answers
SOURCE: Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Posted on Jul 06, 2010
gcken
  • 140 Answers
SOURCE: Webber grill won't ignite
Bad starter you can get one at Home Depot! If that does not work it is a bad electrode!
Posted on Jul 07, 2010
  • 4736 Answers
SOURCE: Need to know how to reset the LP Gas flow for a
If you just installed a new, full tank of propane and turned it on and the burners wouldn't light.
Turn the tank off, disconnect from the grill hose (you'l hear a whooshing sound and smell gas, but that's alright). Wait several minutes and reconnect the hose to the tank. Turn the gas valve on very very slowly, until it's full open. Now, try lighting your grill.
Remember, you will need to turn the tank valve on very very slowly every time you change tanks or turn the tank off after grilling.
What happened was this ... When you turned the tank on quickly it locked up the grill's gas regulator. Doing what suggested usually solves the problem. Oh, one other thing ... be sure your tank is not empty. The grill you have uses a lot of gas.
Posted on Feb 02, 2011
Testimonial: "thanks"
I have a Brinkman BBQ.The igniter works and lights the main burner but when I turn on the second burner it wont ignite.I can light it manually so it clearly it is getting gas. What do I need to do?
Check the igniter with the gas off to make sure the secondary igniter is lighting if it has one. Otherwise reposition the igniter closer to the source. If it isn't flashing, if not, it needs replaced
Nov 16, 2016 | Grilling
How do I convert a natural gas BBQ grill to propane?
You change the nozzle or jet or the complete regulator that regulates the flow of gas. I have seen some company's that will sell you the part or the regulator. You will have to go the the Webber and see if they even offer the part. Or maybe a BBQ dealer who sells and services Webber might do it for you. I know most companies will not sell the part or parts because of the liability. Good luck.
May 21, 2014 | Cook's Essentials Smoothie Maker Work Top...
Ignition button not working, however the bbq will light with a match. I have replaced the old gas bottle and this is still an issue?
Sounds like you need to replace the igniter. If the gas lights with a match, there's nothing wrong with the gas bottle. line or burner.
Jan 28, 2014 | Weber Baby Q Grill
We have a 3 week old Webber Q220 and the ignition does not work - plenty of gas but no spark
Sorry bout your luck. I have a webber. Cheaper modek, and it does the same thing. I.leave my lid closed ...turn it on wide open wait 30 seconds and start lighting.
Jan 01, 2014 | Weber Q Grill
I have a Webber Q Family BBQ for about 2 - 3years. I noticed say last 6 months that the burners are not working properly and the grill is not hot enough ie take 3 times longer to cook a steak etc. I read...
OK, it sounds to me that when you changed the propane tank, you may have turned the gas tank valve on too fast. Doing so causes the built-in excess flow valve to check, which only allows a trickle of gas through. Do this: Turn off the gas tank, disconnect it and drain any remaining gas from the grill by opening a valve to a burner. Close the grill valve and then reconnect the tank. Very slowly open the tank valve and try lighting a burner again and see it that solves the problem. Douglas
Sep 12, 2010 | Ovens
Jul 06, 2010 | Weber Genesis Silver A Grill
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
Right front burner won't burn. Oven will not ignite.
Try lighting it with a bbq lighter. If no gas, then replace the valve. If it lights, replace the igniter. Hope this helps!
Dec 31, 2008 | Kitchen Ranges
Weber gas bbq
Hello stevie66, disconnect the gas tank, carefully remove the burner element (the thing with the small holes) and soak it in a bowl of vinegar overnight. Remove and shack the excess out, remount and connect the gas. Open the gas line about 1/4 turn and CAREFULLY LIGHT. Please E-Mail the results. Thank you.
Oct 26, 2008 | Grilling
Gas hob ignition
1) try leaving it off for a while to see if the ingition box needs to reset
2)when you turn on the burnner does the ignition start by itself or do you have to "ignite" the burnner yourself?
3) if oyu have to ignite the burnner yourself, try using a bbq lighter to see if the gas has gotten to your range yet.
4) if no gas present, there is ussually a reset in the regulator. it needs to be reset if it gets low on pressure. you need to have the lines connected and then turn on the gas AND then the appliance. if the appliance is turned on before the gas in turned on the rest will pop.
lets us know what happens :)
Jan 30, 2008 | Cooktops
Weber Genesis Gold B Grill Logo
154 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
