Question about Pantech Uml290 4g Lte Usb Modem Aircard For Verizon - Uml 290
No power pantech uml290vw
Tried connecting through high speed port hub, and now no power what so ever to wireless modem. almost seems as if it possibly shorted or fried modem since it has always worked before when just plugging into normal port. i have tried plugging into all other ports but now no power what so ever. my question is it possible that plugging into that high speed port hub could have shorted or fried my modem?
2 Suggested Answers
  • 35 Answers
SOURCE: windows/xp driver for pantech duo
Install the latest Duo software load, from:
http://www.pantechusa.com/html/images/software/download.htm
If you still have ActiveSync problems, try:
1) install activesync software
2) On the phone, go to Settings > Connections > Modem Link > then set the modem link status to INACTIVE.
3) On the phone, go to Settings > Connections > USB to PC > then select Enable advanced network functionality.
4) plug the phone in via USB to PC... the sync software will recognize the phone automatically when connected, and windows will not ask for driver install.
-Todd
Posted on Dec 10, 2008
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
I can't get any online connection on my desktop. It is set up with a D link and it's saying it needs to be connected to a high speed port. When it worked before on the same computer it never said...
connect your computer directly to the high speed modem, bypassing the router for a test. You should get online. If not, disconnect power to modem for 2 minutes. Reconnect and retest. if you cant get it to work, call your provider to get this part working. Once working, make sure you connect your modem to the uplink port on your router. if wired on your pc side, make sure connect to the numbered port to test. if wireless then make sure your SSID is transponding.
Jun 13, 2011 | Computers & Internet
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
In the http://192.168.1.1/ dont display the information
1. Unplug the power cable from your high-speed internet modem.
2. Connect one end of the Ethernet cable (included) to the number 1 port on the router.
3. Connect the other end to the Ethernet port on your computer.
4. Connect an Ethernet cable from your high-speed Internet modem into the Internet port on the router.
5. Plug the power back into your high-speed internet modem. Plug the power adapter into the router and wait 30 seconds before plugging it into a power outlet.
6. Wait 30 seconds for the router to fully connect and open an Internet browser window (such as Internet Explorer, Firefox, Safari). Type http://vizio.home or http://192.168.1.1 in the browser window and press Enter. The Quick Start App will automatically start.
Mar 22, 2011 | Vizio XWR100 Wireless Router
4 port 2.0 high speed hub for mac - defective??
No its not defective. If you use your usb modem, plug it in to a working port. It is the default or home port of the usb modem since it was installed on your system. If you use other port for it then it will not work.
Dec 23, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Help
First, FYI, I hope you mean Switch and not Hub and I am to assume your Router's LAN ports are all in use as to why you want or need the 5 port Switch and that you have Wireless Access Points or maybe your Router is a Wireless Router.
Next, you have to connect your 5 port Switch to your Router LAN port. Next you need a Wireless Access Point device to plug into your 5 port Switch. It would be helpfull that all your devices are of the same name brand also.
Now you have a Wireless network.
Thanks,
podum
Sep 11, 2008 | Linksys EtherFast 10/100 5-Port Auto...
Dual Routers?
Disable DHCP in the router. Connect the modem to a LAN jack on the router. You'll have 3 LAN ports. If you need more ports, buy a hub. (You can change the default IP address on the Linksys, but you can't forward through 2 NATs.)
Apr 27, 2008 | Computers & Internet
Pantech Uml290 4g Lte Usb Modem Aircard For Verizon - Uml 290 Logo
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
