Question about Weber Q Grill
We have a 3 week old Webber Q220 and the ignition does not work - plenty of gas but no spark
Problem is as above plenty of gas in our 3 week old Webber Q220 but no spark to ignite - if we wait ages it sometimes lights but with a big whoosh with so much gas - what to do please?
    New Friend:
  • 24 Answers
Sorry bout your luck. I have a webber. Cheaper modek, and it does the same thing. I.leave my lid closed ...turn it on wide open wait 30 seconds and start lighting.
Posted on Jan 01, 2014
SOURCE: ignite prob
You've got two different things going on.  First - the type of igniter used on your model does wear.  I have had mine for over 10 years and have gone through 3 such igniters - and I grill nearly 3 times per week over the 25 week "grilling" season where I live. Spring for the $12 part and just replace it. The other issue sounds like a clogged cross-over system.  I would remove the burners, including the cross-over bar on the far left side that connects them.  Clean the exterior with a stiff steel/brass brush and the inside with a bottle brush.  Make sure all the holes are clear to allow gas to flow easily - use a wooden tooth-pick to do this to make sure you don't change the size of the holes! Put that baby back together and I think you'll find you'll be good as new!
These grills are great.  Now, if Weber could only fix the uneven heat problem between the left and right side I'd REALLY be happy!  (I wish they would even just admit there IS a problem!)
Good luck and happy grilling.
Posted on May 19, 2008
SOURCE: Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Posted on Oct 31, 2008
  • 57 Answers
SOURCE: my silver c igniter does not work..need to
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Posted on Aug 27, 2009
SOURCE: Our crossover igniter won't light. You can smell
It's an electric spark, so lightly sand the electrode tip plus the burner it sparks against. You will be removing rust and grease, probably. Try again. If still no spark, put the tip of a screw driver between the electrode and the burner. If that gets you a spark, adjust the electrode tip closer to the burner
Posted on Jun 26, 2010
gcken
  • 140 Answers
SOURCE: Webber grill won't ignite
Bad starter you can get one at Home Depot! If that does not work it is a bad electrode!
Posted on Jul 07, 2010
I have a 3week old Webber Q220 bbq and it does not ignite - Plenty of gas but igniter does not work - what to do please?
If it's no longer sparking, then it sounds like your igniter battery is dead. Unscrew the igniter button and replace the battery.
Jan 01, 2014 | Weber Genesis Gold B Grill
Jul 06, 2010 | Weber Genesis Silver A Grill
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Faulty Junkers water heater
first find out from your manual what the flashing red light means...that should narrow your search---could be a thermocouple shot,a rubber diphragm in the gas valve has weakened and not operated, or gas pressure into the appliance may suddenly be too low, or springs in gas valve may have worn out---very many possibilities
Mar 02, 2010 | Water Heaters
Igniters will not stop clicking.
Hi
Thanks for using FIxYa.The igniter doesn't stop clicking due to a short inside the igniter circuit or due to moisture present on the ignition switch.Turn off the gas supply immediately and also unplug it from the mains power. Now take a blower or your hair dryer and blow hot air over the igniter. Also check for the following troubleshooting steps---
1) The gap between the igniter and the burner base is too large. *Should be approximately the thickness of two dimes.
2) Soiled igniter or burner base.
The above can be tested by switching the suspected burner with a known operating burner.
3) Loose wiring connections at the igniter, the grounding strap, or spark module.
4) Broken or pinched igniter wire between the burner and module.
Both of the above are physical inspections under the main top.
5) The module may have a week coil, which is not providing sufficient voltage to ignite the gas.
Even after performing these steps the igniter doesn't stop clicking then you need to replace the spark module.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | GE Profile JTP18 Electric Single Oven
One burner does not light up. The ignition is clicking and providing sparks, and there seems to be plenty of gas. It works fine when i put a match to it.
Hi!
Make sure the burner cap or burner head is in place correctly, and that the jet or hole(s) for the ignition are clean of debris. In most cases like this, if there is spark present and no ignition, it means something is either clogged and dirty or the spark is not strong enough due to poor grounding.
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
One burner requires a match to light
had same problem. Used fine sandpaper on the little head (just above the white ceramic) that creates the spark. over the years the edges of the littel metal ring had gummed up but a 1 min sanding got it down to shinny metal and it sparked nicely.
Nov 30, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Hayward h400 (electronic ignition) does not light. Jumped our pressure & limiter switches. Change gas valve. Still not lighting. Have plenty of spark. Help!!
If you have a multi-meter check for 24 vac between OR & W at the board or on the gas valve (OR & W are the 2 wires that go to the gas valve). Check the voltage while the igniter is sparking.
Aug 01, 2008 | Heating & Cooling
Weber Q Grill Logo
110 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
