Question about Fein 9-55-13 Turbo II Bagged Canister Vacuum
Fein Turbo II Vacuum 9.55.13 manual - Fein 9-55-13 Turbo II Bagged Canister Vacuum
Automatic switch works manual switch doesn"t
Could be Dirty switch, Switch is come away from contact (if it has been dropped or taken a hit) or Electronics Failure.
Feb 08, 2013 | Fein 9-55-13 Turbo II Bagged Canister...
Need switch for Fein mdl 9355.13 vac. Where to purchase?
Type www.fein.com in the address line in browser. It should take you to Fein in your country. On the left hand side of screen you will see a list of links click on service then Authorized workshops that will give you a list of places to fine spare parts and repairers.
Mar 26, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
FEIN 9.55.13 WILL NOT TURN ON. SWITCH? BRUSHES?
replacement parts for that model can be found at amazon, click here and take a look: Amazon com fein vacuum parts . Have a nice day
Sep 12, 2011 | Fein 9-55-13 Turbo II Bagged Canister...
I need the orange top cover for my 9.55.13 because mine is cracked. Where can I buy one?
You will probably be able to find it at: http://www.ereplacementparts.com/fein-parts-c-15741.html?osCsid=2cldhjbhfcq03503il7el658t4
Paul
Oct 12, 2010 | Fein 9-55-13 Turbo II Bagged Canister...
Are fein vacumes anti static?
all vacuums create static from friction even plastic cased ones
May 18, 2010 | Fein 9-55-13 Turbo II Bagged Canister...
Vacuum was running unusually hot recently and then
if it was running hot somethinghas melted together and now wont start must be torn apart to see what has failed most likely the vac motor impellar.
Jan 27, 2010 | Vacuums
I need a owners/instruction manuel
Go to www.feinus.com, click on tool diagrams, scroll down to your vacuum model no., click again, and your manual appears in PDF format. Good luck
Jul 14, 2008 | Fein 9-55-13 Turbo II Bagged Canister...
Fein 9-55-13 Turbo II Bagged Canister Vacuum Logo
Top Fein Vacuums Experts
Bill Boyd
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
