Question about Emerson Televison & Video
No signal or low signal and no source list
The source list stays on TV and no other options are listed
  • 979 Answers
SOURCE: no channels on the list
Be sure that you are on the "Tuner" input, and that if you are using a converter box, that you have the set tuned to the single channel that the box puts out. (In the US, that's either 3 or 4.)...accordianman
Posted on Jul 01, 2008
skotkolr
  • 558 Answers
SOURCE: HP PL4260N source list entries are all "Cable"
Video board is most likely damaged from a electrical spike, you may try looking at the capacitors on the boards inside the tv and see if they are damaged capacitors are an easy solution to problems some of the time.
Posted on Apr 28, 2009
SOURCE: i have an olevia 532 b12 model and no tv channels in list
I have an olevia 532 b12 model. I do have cable at my house, straight to tv , no cable box.. but my tv only says a message ''no channels in list'' on the Turner source option. I Just bought this TV with no manual, What do I do in order to see the channels , to me it seems like the remote is locked. I cant change the time date , nothing ? The DVD playes plays and sounds great,,, Its just the cable TV part
Thanks
Posted on Oct 18, 2010
freelance-au
  • 131 Answers
SOURCE: i cannot get a picture on the screen of my tv. I
Hi
Firstly and would remove all the leads from your TV and check them. If after checking your HDMI leads etc... and its still the same then i would reset the TV to the original Samsung settings. This is completed on your remote control by the following........
Turn your tv to standby, on the remote when in standby press the keys on the remote in the following order........ INFO.........MENU..........MUTE.........POWER ON.
You will now notice the picture comes on with the engineers settings in the background. With the direction keys on the remote scroll down to number 12 (RESET) Then press OK or the right direction key, Your tv will switch off and load the Samsung factory settings. Switch the TV back on and go through the setup procedure.Once completed then try your HDMI again.
If it is still failing then there is a strong possibility that your Eeprom IC on your main AV Board is corrupt and needs replacing. This should only be attempted if you have good soldering skills as they are Surface mounted and very small.
My advise if your skills are not that good is just to replace the main AV board (Scart Board) these usually sell for around £50 but WILL solve your problem.
I have gone trough everything i know here that would cure the fault, most times one of the above three will cure this, but im afraid other times its just time for a new AV board.
Hope iv helped some people out here.
Any comments or thumbs up appreciated.
Posted on Nov 18, 2010
  • 127 Answers
SOURCE: cant use source list
You have to go to Input and select and select HDMI. With the remote.
Posted on Nov 03, 2012
42LF20FR
Aerial connection bad!
Oct 04, 2014 | LG 42LG50 42 in. LCD HDTV
Emerson blue screen and source list only shows TV
Check the remote control with fresh batteries. Check its infrared emission. It sounds that the fault is with remote control itself. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Jan 01, 2014 | Emerson Televison & Video
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use antennaweb.org or tvfool.com to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
Jan 19, 2011 | Philips Televison & Video
Toshiba tv 32kv500b, when tryin to install channels came up no signal, checked aerial cable but cannot get back to the installation menu which came up in the beginning, when press menu button a smaller set...
I suspect you are seeing the Main Menu for the source that you are currently using. Press the Source button (TV/AV on the TV itself) and make sure you are on TV source. The menu will have a set of icons if it is set for analog and a vertical list in digital. Select Setup (use the up/down arrows for digital and the left/right for analog - it's the first one in the list) and click OK. Then select Installation (third one in the list) and then press OK. Next select Automatic channel scan (first one again) and press OK. You will see a warning prompt, highlight Yes and click OK to scan for digital channels. When it is done, it will ask if you want to scan for analog channels.
The manual is available here: http://www.toshiba-om.net/LCD/PDF/English/Country_Specific/KV500-32-English-Specific.pdf (direct link to the pdf)
I hope this helps.
Dec 16, 2010 | Toshiba Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
Have a vizio model M190VA 19in. tv. NO SIGNAL is on the screen.
What source is connected to the TV (what input is it looking for)? Check that the cables are fully connected and undamaged. If the source is a set-top box or dvd player, make sure the device is on and works for another TV. If the source is OTA, make sure the antenna is pointed in the correct direction and is getting sufficient signal. (Try antennaweb.org or tvfool.com for antenna direction and signal strength. Antennaweb is very conservative in the list and assumes an outdoor antenna.) If you have an amplifier or splitter, try eliminating them to test just the one tv (I've had several amplifiers turn into filters that blocked one station after lightning strikes). Try rescanning for channels.
Try another station or source. If none of these ideas help, you may have damage to the video input board or a problem with the cable from that board to the rest of the TV. If the tv is out of warranty, open up the unit and remove the shielding. Look at the boards for obvious damage (soot, scorch marks, leaking capacitors (look like cylinders on tripods)). My usual source doesn't list parts for this model TV but you may be able to find the board with the part number on the board itself.
I hope this helps.
(I use shopjimmy.com for reclaimed parts with minimal use)
Sep 06, 2010 | Vizio Televison & Video
Which input do I use in order to watch tv with the s-video cable?
If the signal is coming your computer (laptop) you should connect the S-Video output port of the laptop to the S-Video input port on the TV. Then you use your TV remote to set the signal source to S-Video. You probably have a button labeled A/V, and you have to press it to display on the TV OSD a list of the available signal sources. Use the arrow scroll through the list to select S-Video.
Jan 30, 2010 | RCA F35755MB 35" TV
Ive connected the vga cable and still get "NO SIGNAL" msg.
If the resolution of the source of the RGB signal is outside of the range of the set, you will get this mesage. The supported resolutions are listed in the owner's manual. Verify that you have a signal within that range. If you do, please post your source of the video here and we'll look further.
Thanks,
Dan
Mar 19, 2009 | Vizio VOJ320F1A 32 in. LCD TV
I cannot delete music off ipod nano 8gb help me please
iTunes includes several options to automatically or manually sync videos to your iPod classic, iPod nano (3rd generation), or iPod (5th generation). Read this article to learn more about these two methods.
Products Affected iTunes, iPod nano (3rd generation), iPod classic, iPod (5th generation)
Syncing videos automatically Connect your iPod to your computer and open iTunes. Select your iPod in the DEVICES section of the iTunes Source list.
In the main iTunes browser window, select the Music tab. Select the checkbox labeled "Sync music" and verify that the "Include music videos" checkbox is also selected. You have the option to sync all songs and playlists or selected playlists.
Movies can be automatically synced to iPod. Select the Movies tab and select the option to sync all movies, selected movies, or a certain number recent unwatched movies.
TV Shows can be automatically synced to iPod. Select the TV Shows tab and select the option to sync all TV shows or selected ones. You can also determine which episodes are synced based on if they are recent or unwatched.
Video Podcasts can be automatically synced to iPod. Select the Podcasts tab select the option to sync all podcasts or selected ones. You can also determine which episodes are synced based on if they are recent, new or unplayed.
Click Apply and iTunes will begin syncing the content you've selected to your iPod. Tip: You can use the capacity bar at the bottom of the iPod settings window to determine how much free space is available. The size of a playlist can be determined by selecting it and looking at the bottom of the iTunes window.
The iTunes LCD will display the sync progress and notify you when the iPod sync is complete.
To disconnect your iPod, select it in the Source list and click the eject icon.
Syncing videos manually If your prefer not to automatically sync video content to your iPod, you can setup manual syncing.
In the main iTunes browser window, select the Summary tab. Select the "Manually manage music and videos" option. This will deselect the automatic sync settings for the Music, Movies, and TV Shows tabs. Automatic syncing for Podcasts, Photos, Contacts, and Games can be individually disabled by selecting each of those tabs. Note: When manually managing iPod, disk use is enabled and iPod must always be manually ejected in iTunes before disconnecting.
Click Apply. To manually add music videos, movies or TV shows to your iPod, choose one of these categories under LIBRARY in the Source list. Select and drag items you want (to choose multiple items, Command-click items on a Mac or Control-click items in Windows), then drag them onto your iPod icon in the Source list. To add a playlist, select it in the Source list and drag it onto your iPod in the same ways as a video or song.
When you are ready disconnect your iPod, select it in the Source list and click the eject icon.
Mar 01, 2009 | Apple iPod nano
Televison & Video Logo
12 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
