Question about Kyocera Mita Office Equipment & Supplies
Kyocera KM-2050 C0240 error - Kyocera Mita Office Equipment & Supplies
  • 36 Answers
SOURCE: kyocera km 2050
The 2050 uses 2 network connections, one for the printer and one for the scanner.
Before I go into any great detail,
Do you have a home network? Are you using a switch?
Are you printing through the network connection or the USB/parallel port?
Are you trying to twain scan? Do you have the software CD for scanning.
If not, you will need to download the drivers from the Kyocera web site.
Posted on Apr 08, 2008
  • 66 Answers
SOURCE: Kyocera KM-3035 System Error C0240
this is a printer error
it sound like you tried to update the printer firmware with an unzipped file from an incorrect print system
you need to format the cf card on the PC first then you need to format it on the printer, you will see the card option when you go into the user printer menu. it is print system U
Posted on Mar 10, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
mysticus_tam
  • 38 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
SOURCE: I have Kyocera km-2050 it
press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Posted on Dec 06, 2010
Lost the pin code for kyocera 2050
The default code for the Kyocera KM-2050 is 6482.
Jun 30, 2015 | Kyocera Mita KM-2050 Printer
KM-2050 Printer: i need to find the pin number to my kyocera km-205...
I need to create a new pin on kyocera 5050 machine as the old one is lost
May 05, 2010 | Kyocera Mita KM-2050 Printer
Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Jan 29, 2010 | Kyocera Mita KM-2050 Printer
Kyocera km-2050 scanning function
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
Driver
From links below you can download driver and manual:
KM-2050 driver KM-2050 utility KM-2050 datasheet KM-2050 installation manual KM-2050 user manual
KM-2050 documentation
Do not forget to rate the solution.
Thanks
Feb 23, 2009 | Kyocera Mita KM-2050 Printer
Nov 01, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera 2050 Has set toner error
Take out the toner and clean all contacts that you see. and make sure that it is seated properly. if the contacts are not touching it will not see the cartriage.
Aug 13, 2007 | Kyocera CS-2050 Black and White Copier
24 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
