Bosch maxx classic
We have a Bosch max classic front loading washing machine which is now boiling water even on cold water cycle.
  • 6 Answers
SOURCE: Smellly Bosch Max 1000 front loader washing machine
(Posted this already, but found an AU site that sells Norwex detergent - a great product!)
We've had our Fridgidaire front load washer for 6 years now, and untilabout 2 months ago, it smelled absolutely horrible. I tried the thingsI was told to do....hot water/bleach cycle, wiping the slime from therubber seal, and leaving the door open....it didn't work.
Iwas told about Norwex laundry detergent - Norwex is a company whichproduces green cleaning products - the detergent is a quicklybiodegradable, highly concentrated powder, and all I need is 1/4 - 1/2a teaspoon per load. After about one week of using the Norwex detergentI noticed that the smell was completely gone and hasn't returned! Also,the gross slime that used to collect in the rubber seal is no longer aproblem. I've been so wonderfully amazed!
I don't know why thisdetergent fixes the smell problem, but I've talked with others who havehad the same great results with it - their smell issue was solved.Perhaps it's because it contains no animal fat products?
Anotherbenefit of the Norwex detergent is how economical it is - it comes in a2kg bag for about $25, and in a front load machine you will get approx.800 loads from it using the above mentioned quantity/load! It's reallyan amazing product! You can buy it online - www.norwexnaturallyclean.com.au (an Australian site) is a great site to buy from. Good luck with the smell!
Posted on Apr 18, 2009
SOURCE: Bosch Maxx Instruction Manual
F:16 - Doors are not properly closed. Check the doors are closed with no obstacles.
F:17 - Water is not running. Check the tap, hose and filters. Also water pressure can be low.
F:18 - Too much water remaining. Stop the drying program and start Spin program. Otherwise something is bolcking the water exit from the machine.
Posted on Jul 16, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
57 varieties
  • 1653 Answers
SOURCE: I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Posted on Oct 02, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
Cold water needed only on my Bosch Maxx washing machine one fabric needs cold water
normally a setting on them by turn switch if not select a cycle that only adds cold water
Oct 25, 2017 | Bosch Washing Machines
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Is there a awy to default water temperature to COLD
unfortunately no there is no way you can alter the way the max defaults as it is programmed into the module
Dec 30, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
