My martec fan remote not working - Televison & Video
Can only get one low speed operation on Martec remote control ceiling fan
Look at the fan base and see that the setting, usually on a chain. Pull the chain should change the speed.
Jan 05, 2018 | Dryers
Martec quadrant DLQ134B -Why - I have two fans which only just operate on low, no other response to medium or high. Have replaced batteries to controllers but makes no difference to the operating of same
Considering you have the same problem with both the fans and using law of probability I would say your fans are ok. My guess is that you are operating the fans in winter mode (reverse). In this mode the fan only works on low speed for obvious reasons. Switch the fan to Forward mode (using remote control) and check if the 3 speeds are working.
http://www.martecaustralia.com.au/products/ceiling-fans/martec-ceiling-fans/quadrant-series/quadrant.html
Apr 24, 2014 | Dryers
Martec series 1344 ceiling fan how do I install it
try looking at the manual. you might be able to find the manual here.
Click here for Ceiling Fan Manuals
if that doesnt help then try leaving a message on the site with the manual you need and they will upload it for you.
Dec 14, 2013 | Electrical Supplies
Ceiling fan not wirking on Hi.
Check the brushes driving the solenoid,they may have worn out
Nov 12, 2013 | Dryers
Martec ceeling fan/light wiring diagram needed or step by step guide for connecting wires.it was a mess and all not workin so need to get sorted asap.someone help.
depends on how your ceiling box is wired. if your box has a black, white, or green or bare ground you need to twist your blue and black wires together and connect to the black wire in the box connect white to white and green to the green/bare wire. if you have a three wire connection (black,red,white,green/bare) you connect red to blue black to black white to white and green to green/bare
Apr 05, 2012 | Home
I have to change my light/fan combo wall switch 'cos the fan knob broke. Previous switch was a Martec & the new one is an Arlec. The Martec was wired 2 reds to 'A' and 1 red to 'F' on the fan...
Do not use the capped off black wires. Leave them be. You need the same wires to perform the same functions as before. Of this I am certain. I don't know those particular switches, but here's an educated guess about the rest--- I am assuming that the 3 black wires are connected together with one wire nut. The single red to F is the output to the fan, you have that right. The pair of reds to A are an incoming hot wire, and an outgoing hot wire to another box or outlet that is just passing through. These must remain together. Your old switch had an internal jumper that fed power to both the fan controller and the light switch. Your new light switch is a four-way switch that can be used just fine in your case, but it will require you to add a jumper wire. A 4 way switch can't be used as a 4 way switch if it had an internal jumper from the fan control, so you will have to provide the jumper from that pair of red wires (making them a trio) to one of the 4 terminals on the light switch. Your white wire will be connected to one of the other 4 terminals. Of the four terminals on the switch you should probably use one of the top two and one of the bottom two. If nothing happens (unlikely) then use the top two or the bottom two. If one top and one bottom works but your switch is upside down (the up position is OFF and the down position is ON) then trade one of the wires left and right. If this was helpful, please vote. Thanks, Al K
Mar 09, 2010 | Electrical Supplies
Fan remote nor lights work.
FIRST CHECK THE WIRE CONNECTIONS IN THE FAN ARE NOT LOOSE ,IF ALL CONNECTIONS ARE GOOD THEN I WOULD SUGGEST YOU REPLACE REMOTE.
Nov 08, 2009 | Dryers
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Jul 12, 2009 | Universal Remote Control Hampton Bay...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
