Panasonic na-140vx3 wont drain
Ur washing machine has started a wash and part way through the cycle it tells us it cant drain i have drained it twice and restarted it but get the same problem
  • 1462 Answers
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Posted on Jun 26, 2008
  • 30 Answers
SOURCE: my washing machine wont drain the water
Sounds like a blocked pump.The pump could be burnt out.
Posted on Aug 03, 2008
  • 21 Answers
SOURCE: Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Posted on Dec 29, 2008
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Please tell me if an NA VR5500L Panasonic washing machine has a water heater? If it does, how does it work? the drain coming out is cold. THANKS A LOT
The only appliance that heats water internally for cleaning is a dishwasher. Washing machines don;t heat water. It's not efficient. Various industries have work their hardest to keep you from using hot water or the chemicals(phosphates) that help you clean better without it. Dishwashers warm 3 gallons no more than 20 degrees during a 30 minute cycle. Some washing machines are designed to avoid hot water completely and call themselves energy effient to get people to buy them. My wife would cut my heart out if I brought one home.
Aug 24, 2015 | Washing Machines
PANASONIC-na-f70B2 drains as it fills to begin wash cycle. Error code U14
You water drain line needs to be curved above top of tank Water finds its on level The water level is stuck on the full position shake the washer lightly with water inside to release it. It works almost as a toilet tank.
Feb 15, 2015 | Washing Machines
Kenmore top load washing machine stops cycle wont drain water
Amber, you probably have a broken lid switch. They will not let the machine go into drain and spin because it thinks that the lid is open.
Aug 13, 2014 | Washing Machines
Error code h41 on panasonic washing machine model na-168vx2
U11
The washing machine cannot drain
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Feb 15, 2011 | Washing Machines
When we attached the machine and started it we realised the water is draining out from the drum. this happend with our previous one too . cant understand
That is the problem of washing machine!
Check ur DRAiN valve and solenoid!
Either ur DRAiN valve stuck OPEN because of those DEBRiS from ur clothes or coins from ur pants!
Nov 07, 2010 | Hoover Washing Machines
My washing machine wont drain water
if waser wont drain it cant spin and some contorl boards get confused about that situation.check your pump,is it clear will it funktion.other wise i dont know a lot about this proticular machine god bless,tom
Jan 01, 2009 | Candy Washing Machines
Jun 26, 2008 | Washing Machines
Washing machine
something caught in pump or bottom drum hose,check filter also!!
Mar 19, 2008 | Washing Machines
Washing Machines Logo
202 people viewed this question
Top Washing Machines Experts
