Question about Nikon ProStaff Laser 440 Rangefinder
Rangefinder not picking up flag - Nikon ProStaff Laser 440 Rangefinder
3 Suggested Answers
SOURCE: even with new batteries, this nikon golf
On my Laser 500 G I held both buttons down simultaneously for a short time and it began finding pins again.
Posted on Aug 06, 2010
elix0411
  • 3530 Answers
SOURCE: My rangefinder was dropped and now the view is
Welcome to Fixya
Looks like the unit has been damaged after the incident. Try to resetit first by pushing the mode button and the power button simultaneously for 30 second. This will reset the device. If same problem after the reset, you need to contact nikon for repair. There might be loose parts or cable inside the unit.
Thank you for using Fixya!
Posted on Jun 22, 2011
Inconsistent and unreliable readings
A flag is a hard object to get a reading on. It constantly moves and the sound or light waves (depending on the model) will not be reflected consistantly. Clean the sender lens and the receiver lens and install new batteries. Recalibrate the unit using something stationary, like a FLAT wall.
Oct 03, 2009 | Bushnell Pinseeker 1500 Rangefinder
Pinseeker 1500 has trouble picking up flags over 100 yards away
The unit needs an alignment. Vibration and dropping the unit is the number one killer of rangefinders.....After a while of using them, (bouncing around in golf carts, cup holders, dropping them on the cart path, or the ground) small prisms start to move inside and decrease the units effective range.... (only able to hit a target at about 150 yards or less) People that use these type of instruments have to realize that the laser beam is the straightest line in the history of man!!!. Alignment is crucial!!!
Alignment is due. For all you players that think its okay to take off the eyepiece cap.....(bad idea) This is why you see oily looking spots or black spots in the view. Direct sunlight will be magnified and burn the surface of the LCD. Bushnell is good about warranties but, if you take it apart...the warranty is void!!!! So if its 2 years old or less.....(send a copy of the proof of purchase) .send it to them. If you have sunlight burns already...this won't effect the performance of the unit. Wait till something else is wrong.
mr tech geek Rate me if you can...or find out this is the truth!!!!
Bushnell Repair Technician
Service address:
Bushnell Repair Centre
8500 Marshall Drive
Lenexa, KS 66214
send $10 for return shipping
send your problem statement and phone number.
Their number is 800.423.3537
Jul 16, 2009 | Bushnell PinSeeker 1500 20-5103...
I have a Bushnell Medalist Pinseeker golf laser rangefinder. I recently replaced the battery with a 9V Duracell Alkaline, and now the Pinseeker mode is not working (it will not sight different targets) and...
The "Pinseeker" mode is a automatic mode Sometimes it uses it, somtimes it doesn't. It is designed to recognize a vertical shaft. (Pin) Now IF you hold the power button down....you can see if all of the LCD segments are burning. If the segments fade out later in the game.... (bad LCD) Make sure the Pinseeker mode it on...(flag symbol on the left) Hit the button on the side if you need to. IF it still doesn't lock on to pins, it needs an alignment.
MTG
Jun 23, 2009 | Bushnell Golf Medalist BUU0055 Rangefinder
Will not pick up the flag over 150 yards.
You need an alignment. The transmitter and receiver are not pointing at the same spot. The farther the distance the bigger the gap between the two. Dropping the rangefinder and vibration are killers to Pinseekers. Bushnell will fix ya.....
Mar 12, 2009 | Bushnell Pinseeker 1500 Rangefinder
Incorrect distance or Calabrated wrong
Sounds like the unit is reading in meters instead of yards....Hold down the mode button on the side for about 5 seconds. It should switch modes.
Jan 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
What should focus point be?
For the model you have (20-1916) I would use the flag. Larger target and soon to be reflective. When on the green I would aim at the hole. Let me know if this helps
mtg
Jan 03, 2009 | Bushnell Optics
Just a question
no i have found the actual flag is pretty accurate as long as its not black- the reflectors increase accuracy over distance
Dec 24, 2008 | Bushnell Tour V2 Pinseeker Laser...
Just a question............my understanding is that a Bushnell V2 Rangefinder does not require reflectors on the pins.........is that correct?
not required- in does increase measuring distance past 300 but w pinseeker and most approach shots from 250 in -plain flag is plenty
Line-up flag
Line up the vertical part of the cross-hair with the flag pole for best results. There are some tips on the Bushnell Golf Website: http://www.bushnellgolf.com/index2.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | Bushnell Yardage Pro Tour Rangefinder
Nikon ProStaff Laser 440 Rangefinder Logo
78 people viewed this question
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
