Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VG700b bug
When i turn on my PC, i can briefly (1sec) see on my sreen and then it turn black. And the little light pass from green to orange. Thanks for your help
  • mikethepike1 May 21, 2009
    Thanks a lot for the answer, i'll check it soon and will give you feedback.
The light turning to orange means the monitor is not getting a signal from the computer. Check your monitor cable at both ends and make sure it is in very tight and secure at the computer end as well. Also check to see if the computer stays on when the light goes to orange on the monitor. The power cord for the computer might be loose.
Posted on May 21, 2009
Visco vsc20v1 will not powers on and right back off
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Element Electronics FLX3711B 37 in. LCD TV
Viewsonic n3252w psu change,pwr on screen go blue 1sec.to black
The main board will have faulty component/s. Seek tech support.
Jun 07, 2012 | ViewSonic N3252w 32 in. LCD Television
Hello the speaker on my viewsonic vg700b are not working is there anyway to fix that?
Yes. It probably is, but you need to take the monitor to a specialized workshop to check the buzzers and all the speaker components. It is not a thing to do it alone at home. If you need further assistance or have further questions please leave a comment. Cheers
Aug 26, 2010 | ViewSonic VG700b 17" LCD Monitor
I have a viewsonic VG700b monitor. Everything is fine for the screen but the built in stereo speakers don't work. I'm pretty sure the wires are in the right place so can anybody help me????
First make sure that you are using the mini stereo male phome jacks on both ends, one end is connected to the Green audio line in of the monitor, the other end should be connected to the Green audio line out of the PC, also need to set the volume controls at the PC and the monitor, starting at 1/2 level. You can also verify that the monitor amplifier is wprking or not by feeding it with an MP3 player or some kind of audio source to see if you do get the sound OK.
Mar 14, 2010 | ViewSonic VG700b 17" LCD Monitor
Cant get monitor to turn on. Have tried different outlets. The green light is working on the battery pack.
Press Fn F4 when computer is on.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 02, 2010 | ViewSonic VG700b 17" LCD Monitor
Is this right for my broken view sonic VG700B ?? Size: 2.6mm x 342mm Part Number: 26342 Starting Voltage: 1500 Running Voltage: 650 Current: 5ma Wattage: 3.35 Intensity: 34,000 cdm2
Is this information from LCDPARTS.NET? I always remove the old lamp assembly and take an actual measurement of the lamp dimension before I place the order. The diameter is correct, but you should measure the length of the lamp, I know LCDPARTS.NET does give you some idea how to estimate the lamp size.
Are you sure that the lamp is bad, the common symptom of bad lamp is that it has pinkish light color wwen it first start up and slowly turning to normal white color light after warm up.
Jan 21, 2010 | Samsung Viewsonic VG700B Monitor
Viewsonic vg700b lcd monitor screen turned black
there's an internal hardware problem in your lcd monitor - cold soldered / defective electronic part/s. I suggest to bring the unit to an authorized service center for proper diagnosis & fix the problem. best regards
May 21, 2009 | ViewSonic VG700b 17" LCD Monitor
My viewsonic vg700b turns on but the screen is black
Have you found a solution?
I have the same problem
Apr 01, 2009 | ViewSonic VG700b 17" LCD Monitor
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Monitor Colour
for whatever reason you have lost your blue gun. it could be a matter of an adjustment or a defective component in the blue video driver. take it to have it serviced.
Jun 20, 2006 | ViewSonic VG700b 17" LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
351 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
