Question about Kodak EasyShare C142 Digital Camera
Memory card unusable
I bought a new memory card and I done everything it told me to do and it keeps saying memory card unuseable
Habubnik
  • 114 Answers
SOURCE: "Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
Posted on Aug 29, 2005
Tri3mast
  • 747 Answers
SOURCE: My old memory card all
Try putting the new memory card into the camera and format the card. If the camera doesn't accept that it has a memory card turn the camera off remove the battery and then after about ten seconds put the battery back in and turn it on and see if you can format the new card again. You should always format the memory cards in the camera, even though there is a delete for single images leave them on the card and format the card. Always format the card in the camera not the computer.
By deleting single images in on the card while in the camera it sets up little partitions and pretty soon the memory card is rendered useless. Formatting in the computer writes a little program to the card which the camera can not read.
Posted on Dec 21, 2010
Tri3mast
  • 747 Answers
SOURCE: Just purchased and installed SD
A bunch of stuff could be happening. First did you format the new card if not see if it can be formatted to the camera. if not then you will need to download the newest updates for that camera from the Kodak web site. For example the camera is set )internally) to accept a 1gig card and you installed a 2gig card it won't recognize the card until the camera firmware is updated. The easiest way is to format the card first.
Posted on Dec 24, 2010
Tri3mast
  • 747 Answers
SOURCE: THE CAMERA WILL NOT EXCEPT THE SD CARD,SAYS IT IS
All memory cards need to be formatted to the camera they are going to be used in. By doing this cleans the card and makes it ready to work properly in your camera. After using the card and downloading the pictures to the computer the memory card should be formatted again to give a clean card to put more pictures on. The SD cards also have a lock so you need to make sure that this lock is in the unlock position before installing it in the camera. On the upper left corner you will see a small white switch make sure this has been slide forward toward the top edge (towards the gold contacts) Insert it in the camera and close the door see picture.
Using the set up menu page 32 of you manual will show you how to get to the format menu
Page 33 has the format sequence to follow
Hope this was a help Robert in Canada
Posted on Dec 27, 2010
  • 11967 Answers
SOURCE: Hello! We just opened my
Some cameras can only use SD cards...not SDHC cards. Check your manual.
Posted on Mar 12, 2011
Garmin Nuvi 360 says memory full cant reset
Connect the unit up to a PC and try deleting some of the unused text-to- speech (TTS) voices. Keep only the ones that you need. Delete any unused photos or MP3's...and also any unused vehicle icons on the unit. When the unit is booting, it loads in all of the vehicle icons allowing you to change the selected vehicle, so this too uses up valuable memory.
Apr 08, 2013 | Garmin NUVI 360 GPS Receiver
When i turn on my camera it says Meomory card unusable insert new memory card
Try formating the memory card using the camera's Menu - select format memory card.
Feb 27, 2013 | Kodak EasyShare Z710 Digital Camera
My kodak 1073is camera keeps telling me to format my new sandisk sdhc memory card when I do it tells me to insert a new card
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
Jun 23, 2012 | Kodak EasyShare M1073 IS Digital Camera
I have bought a new memery card 4Gm and tried a old one that worked in another camera it says unusable
If all memory cards did not work then the fault is in your camera, it needs to be repaired.
May 22, 2012 | Kodak V803 Digital Camera
My old memory card all of a sudden reads unusable, So i bought a new one...and it still says unusable... what do i do? I have only had the camera for 4 months
Dec 20, 2010 | Kodak EasyShare C142 Digital Camera
SDHC card won't work
Your card is an SDHC, your camera supports only SD/MMC cards. I know this because i found thisp ostlooking for a way to make it accept SDHC cards, a software update could easily work in theory but someone would have to write that update. Technology changes fast doesnt it.
Dec 22, 2008 | Kodak EasyShare Z710 Digital Camera
My pearl 8120 automatically deletes messages and call logs on my phone
Mine was doing the same thing. I called ATT and was told to remove and reinstall the battery and the sim card making sure the sim was in tightly. once i done this it hasn't happened again
Dec 10, 2008 | RIM BlackBerry Pearl 8120 Cellular Phone
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare C142 Digital Camera Logo
14 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
