Question about iPhone Apps
Ford motor problems - iPhone Apps
How to acces the 4 nuts on a ford transit starter motor as u tube suggest cuting a hole in the body of my van ,are there special tools to do it
which mark version /model /year transit van do you have
most starter motors for the ford transit diesel or petrol
show pictures as only two bolts to hold them on
between exhaust and motor/gearbox housing
Ford Transit Starter Motor Starter Motor For Sale New and Used
this one with three bolts may be a bit of a problem
FORD TRANSIT MK3 MK4 MK5 2.5 D Di TD 2.5 DIESEL NEW RMFD STARTER MOTOR 86-00
Dec 06, 2016 | Ford Cars & Trucks
I own a 02 foard explorer shift motor was bad i think and i removed it, i started it to relocate it, installed the new shift motor
Don's 1999 Ford Ranger shift motor PROBLEM SOLVED ...
? 13:05
https://www.youtube.com/watch?v=wcn39gwPWfI
Oct 1, 2013 - Uploaded by gtarman49
Don's 1999 Ford Ranger shift motor PROBLEM SOLVED. ...How to find replace fix 4x4 transfer case shift module 2002 Ford Explorer 4 wheel ...
How To Install Replace 4x4 Transfer Case Shift Motor Ford ...
? 9:15
https://www.youtube.com/watch?v=9ldrtZODxQ8
Oct 26, 2010 - Uploaded by 1A Auto Parts
How To Install Replace 4x4 Transfer Case Shift Motor Ford Explorer .... transfer case shift module 2002 Ford Explorer 4 wheel drive not working ...
How to find replace fix 4x4 transfer case shift module 2002 ...
? 3:07
https://www.youtube.com/watch?v=sZw3SS2Pt-4
Nov 3, 2013 - Uploaded by kirk colombo
... transfer case shift module 2002 Ford Explorer 4 wheel drivenot working ..... I replaced the transfer motor so i think it is the control module.
Jan 08, 2016 | Cars & Trucks
I have a Ford f150 and the heater does not work at all it will not blow nothing what could be the problem
Check blower motor fuse, if ok see if you can jump out the blower motor to see if it works. If it does check blower motor switch.
I had a ford contour the melted down the switch, some of ford wiring is underrated for the amperage.
Nov 29, 2015 | Ford Cars & Trucks
We have a 1990 Ford aerostar minivan and the blower motor isn't working. I don't know where the resistor is or where the blower motor is located. Anyone know?
Blower motor is in dashboard. Problem could be with motor windings, bearings, fuse, relay, and switch. Check them all out.
Nov 13, 2015 | Ford Cars & Trucks
Will a motor out of a 1986 interchange with my 1990 ford ranger
Should bolt in, depending on size of the motor if it's the same 3.8, or 4.0 (6 cylinder) or four cylinder. The problem with using a different size is wire harness, exhaust and the peripherals. But 86 to 90 didn't change very much it's after 93 that Ford made a lot of changes. Hope this helps...
Nov 07, 2015 | Ford Cars & Trucks
My heat in my ford van stop working the blower isn't blowing no more when I tur the fan on high
Sounds as if the blower motor has gone out. Need to check for power and ground supply to the motor. If both are present then the motor is bad. If missing power voltage,check the fuse. If missing ground,check the blower motor resistor.
Feb 21, 2015 | Ford Cars & Trucks
2007 ford edge power window go's down but not up
most likely your window motor is out or the window brackets arent attachted anymore i would say window motor for they do the exact same thing plenty of power going down because of no force with the window be rolled up its working against gravity and your motor for your window just doesnt have enough power anymore which unfortunately ford cant seem to figure window motors out because thats always a problem in every ford ive ever had way to go ford right??? anyway hope i helped.
Mar 19, 2013 | iPhone Apps
2000 Ford Expedition front air not blowing
TRY JUMPING THE BLOWER MOTOR APPLY 12 VOLTS TO THE MOTOR IF IT STARTS THEN THE PROBLEM WOULD BE THE SWITCH IF IT DOES NOT START THEN THE MOTOR IS THE PROBLEM GOOD LUCK HOPE THIS HELPS
Jun 25, 2009 | 2000 Ford Expedition
The driver side window on my 2003 ford expedition will not roll up or down. Is it the fuse?
I don't believe there are individual fuses for each window, it may be the switch or the window motor. My guess, it's the motor. You can remove the door panel and trim, unplug the connector to the window motor, press the window switch while using a test light to see if it's getting power, if it is it's the motor.
Jun 24, 2009 | 2003 Ford Expedition
2000 ford explorer fan blower only works intermittently
On ford vehicles the blower motor resistors are the most common problem when this happens.
Dec 20, 2008 | 1995 Ford Explorer
iPhone Apps Logo
67 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
