Kodak com go aiosupport
3802
SOURCE: Error 3802
printer can not talk to printhead... power off. wait. power on
Posted on Sep 17, 2008
yooperbud
  • 8637 Answers
SOURCE: i have just bought a
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
SOURCE: kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
Posted on Apr 19, 2009
DMZ ZONE
  • 53 Answers
SOURCE: printer is saying error code
HI,
This is how I fixed this problem may or may not work for you. I removed the ink! Then I removed the ink tray. This is fairly easy if you fell the top of the ink tray you will find a small square that is slightly raised push in on the square while pushing down on the tray this will release the print head. Very carefully clean with 92% alcohol and a q-tip! Don't apply pressure to the print head it will ruin it!
This allow to air dry for at least a 5min. Reinsert then recalibrate the printer! go to printer status and at the very top you will see a rench and hammer icon press it then follow directions
Thanks and regards
Long live the geeks!
Posted on Dec 06, 2010
samaddar07
  • 639 Answers
SOURCE: www kodak com go aiosupport How to use for scanning a document and sending it to a recipient
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Posted on Oct 24, 2011
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
Printer showing error code 3802, says to go to kodak. com/go/aiosupport
I am new user of Kodak printer and i used to get error code 3802.
The main cause of the error 3802 is improper installation of printer driver. To get rid of this error you always ensure that properly install the printer driver.
I was looking for the solution and then found this using google. I found this link helpful.
http://printersupportsnumber.weebly.com/blog/kodak-printer-error-code-3802-its-cause-and-solution
Any other suggestions are welcome.
Thanks in advance.
Jan 20, 2012 | Office Equipment & Supplies
Printer will not clear the Error 3802 , what do I do?
Hello and Welcome to FixYa!
Error 3802 generally occurs in the Kodak Inkjet Printers.
To solve this error Turn the printer off and then turn on, this problem is solved by doing this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If you are still facing this then do it again almost five times & if still your problem is not solved and you still get error code 3802 then probably your KODAK EASY SHARE 5500 All-In-One Ink Jet Printer is in need of servicing by a service professional.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you and Keep using FixYa!
Aug 17, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printhead failure error code 3802
You need to contact kodak and ask for a replacement print head, explain the code and whats been happening.
www.kodak.co.uk
They will probably tell you to download new drivers and wash your printhead ect ect but nothing that helps.
I had the same problem with the same printer.
I couldn't get Kodak to send out a printhead, so after weeks of messing around, I took it back for a refund.
If you do manage to get a new printhead here are the instructions on how to remove and replace it.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Jan 31, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Error 3802
Sep 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
274 people viewed this question
jasbo
jasbo
