Question about Pacific Image Office Equipment & Supplies
Watts film scanner - Pacific Image Office Equipment & Supplies
Can not remove film tray from scanner . Film tray is stuck
I have turned off the power and then used a wire hook manufactured out of a coat hanger to pull it out. My problem is not with it getting caught but with trouble locking the film in place. Any problem or solution for that?
May 14, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
Problem scanning film with EPSON V300
check if upper cover remove for film scanning, bulb must be visible upon scanning in negative or positive film.
Feb 04, 2010 | Epson Perfection V300 Film Flatbed Scanner
Kodak 3000 DSV Film Scanner , Film Scanner Driver drivers need
You have to Change the scanner vendor name to MS7000 and then use the Minolta Twain driver listed on their web site...USA site!! there are no Kodak drivers for this unit other then the application software Powerfilm.NO kodak windows drivers either , it uses ASPI drivers.
Aug 31, 2009 | Kodak 3000 DSV Film Scanner (35 mm), Film...
How do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Jul 07, 2008 | Canon CanoScan 8400F Flatbed Scanner
Nikon 8000 film scanner problem
I If you use nikon scan you get a different error warning Update nikon scan and also gdiplus.ddll update from thre nikon web site. It worked for me.
Jul 04, 2008 | Nikon Super Coolscan 8000 ED Film Scanner
Huge difference in film scanning quality
For ARCHIVAL quality scans, there is no comparison. The Nikon wins hands-down. For making small prints and web sharing, either will work fine.
Apr 16, 2008 | Nikon LS5000 Film Scanner
Scanner not working
hrm, i found out how to solve the issue. remove the film and do a calibration for the frame, now the scanner starts to calibrate, after a 30sec the program told me to put the film in and scan.
tadaaaaa..
Jan 13, 2008 | Canon CanoScan LiDE 500F Flatbed Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Coolscan ed 4000
The scanner has a lock which locks the film adapter into the scanner when film is inserted. You probably still have film in the adapter from the last time you used it. If the adapter is pulled to remove it, the connector can become disconnected, which prevents the film from coming out, but the latch is still engaged. With the scanner off, push in the adapter to mate the internal connector. Turn the scanner on then off, the film should eject. Once the film is ejected, the adapter should be able to be removed. Refer to your manual for reference to this problem, I have experienced once before. Once you figure it out, you will not forget, I guarantee.
Aug 15, 2007 | Nikon Super Coolscan 4000 ED Film Scanner...
67 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Willem.
Willem.
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
