Question about Thermador SC272T Electric Double Oven
Thermador double oven replace fuse - Thermador SC272T Electric Double Oven
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
  • 9 Answers
SOURCE: Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Posted on Feb 06, 2009
vetteman3002
  • 2299 Answers
SOURCE: Thermador SC272TS (1998) Double Oven. Bottom oven
Usually it is the thermostat that causes both the boil or bake not to work. If it was one or the other it would be a different problem. But the thermostat is telling the controller that the temp is already to high. And will not let the elements heat up.
Posted on Oct 25, 2010
SOURCE: After self cleaning my Thermador double oven, it
Never use Self-Cleaning!!! It will fry components, melt connectors, and burn wires. If you have violated this rule and an oven no longer works, it is probably not a bad element if neither the bake nor the broil work. It is likely the high heat cut out breaker.
On a Thermador CT 227 double oven, there is a panel on the right side (facing the unit) that is about 3 inches wide and runs from top to bottom held in place by about 6 or 8 screws. Turn off the power, slide the unit out of the kitchen cabinet, remove the sheet metal panel and you will see two high heat cut out breakers. They have a small red button in the center that resets the breaker. Push firmly and you should hear a click. If there is no click, check the unit for continuity. If it is open and the button push does not reset it, the unit may be fried. These breakers trip with high heat and will prevent both elements in an oven from heating. If the breaker is good, you'll have to test the leads to each element and then trace the dead lead to the problem.
Posted on Dec 28, 2010
Help!!! Need Replacement knob kit for my Thermador double oven!
these are NLA. No Longer Available.
Try to get something that is acceptable to you and fits by researching "oven Knobs" at repair clinic dot com and selecting by looks and size.
Nov 09, 2013 | Thermador SC302T Electric Double Oven
Thermador SCD302 NO Illumination on Display window
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
Sep 27, 2010 | Thermador SC302T Electric Double Oven
Thermador wall oven doesnt heat up after being self cleaned
This may be the thermal fuse mounted on the back panel or you may have a failed control. We rebuild Thermador control boards at www.fixyourboard.com
Jun 02, 2010 | Thermador C302U Electric Double Oven
Front panel light is fading
Had the same problem. Replaced the display board.
Apr 12, 2010 | Thermador SC302T Electric Double Oven
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
Thermador SC302 double oven the top oven is not getting hot
We've had the same problem. I contacted a local sales room and they contacted their rep who promptly mailed the replacement parts I requested (I'd looked up the part numbers already). Now I'm waiting to find someone who will reasonably do the work.
Aug 10, 2009 | Thermador SMW272 Electric Double Oven
Jan 30, 2008 | Thermador SC302T Electric Double Oven
Thermador double oven SC302 Fault code F34
first check to see if the oven is under warranty it might also be a manufacturers defect
Dec 30, 2007 | Thermador SC302T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Thermador SC272T Electric Double Oven Logo
43 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
