Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
After the clothes spin out the bottom ones are still soaking wet
I have a top loading whirlpool. The clothes spin out but I don't think all of the water is draining out.
  • scottjones20 May 21, 2009
    I found no clog, could it be the clutch sliping with a full load?
  • Whirlpool Master
  • 3,361 Answers
Remove the pump and check for obstruction. This video will help you to access the pump.
Posted on May 20, 2009
  • steve
    steve May 21, 2009
    If it is not spinning full speed, yes, the clutch/brake could be defective.
Drum not spinning
Sounds like the belt has popped off of the pulleys under the washer.I would check that first
Mar 15, 2014 | Whirlpool Cabrio WTW5600XW Top Load Washer
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
169 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
