Clock radio WCR-11108
WhiteWestinghouse clock radio WCR-11108 clock radio. Need to know how to adjust and display time.
SOURCE: Clock on Bose Radio
Push & hold Clock Set Button. While holding, push On/Off button,
Thank You, FixYa Community! Thank you! Thank you! Boy, that one was not obvious.
Posted on May 03, 2008
SOURCE: Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Posted on Jun 16, 2008
Hello everyone,
I finally found a manual that I hope that it will help you as much as it helped me. It took long enough. Here goes; try this site:
http://www.emersonradio.com/owners/SmartSet%20Series/
Posted on Aug 10, 2008
  • 814 Answers
SOURCE: SmartSEt Clock Radio went to military time
You can reset the time from military to regular time by holding down the time button and let it cycle to the normal time. I hope this information help you with your problem.
Posted on Jun 11, 2009
SOURCE: FM/AM GE Digital clock radio model#7-4966 display bulb burned out
Geri, I recently had the same problem with my GE model 7-4966 clock radio. The radio manual states that there is a spare bulb included and stored on the underside of the battery compartment door on the bottom of the clock radio. To replace the bulb: 1. Twist the bulb bar handle on the underside of the radio to unlock and remove the holder. 2. Carefully pull the bulb out of the holder and replace with the spare bulb. 3. Place the holder back in place, twist the bar handle to the right to "lock" the bulb holder in position.
In case you can't find a spare bulb, the manual states "use only a GE259 or equivalent 6.3 volt, wedge base bulb. A clerk at Radio Shack told me she could get a replacement bulb.
Dennis60
Posted on Jul 27, 2009
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
Teac model LT-1 how to set clock
To set time on TEAC CD Receiver LT1
Press Memory/Clock Adjust button until numbers flash.
First display is 24/12 for choice. Change with >>> button.
Press Memory/Clock Adjust button again and Hours digit
flashes. Set with >>> or <<<.
Press Memory/Clock Adjust button again and Minute digit
In 12 hour mode "PM" will be displayed
Sep 23, 2012 | Teac LT-1 Clock Radio
SETTING CLOCK ON JENSEN PHASE PCD120U
Display Selector (DSP)
This unit can display either the clock time or
radio frequency/CD player functions. Ordinarily,
the radio frequency or CD player track
indication is displayed, but the unit will display
the time when the DSP button (18) is pressed.
The time will display for approximately 5
seconds then return to the radio or CD player
function display. The correct time-of-day can be
set by pressing and holding the DSP button.
Setting the Clock
To set the clock, perform the following steps:
1. Turn the vehicle ignition and radio on.
2. Press and hold the DSP button (18) until
the time display flashes.
3. Within 5 seconds, turn the MULTI/JOG
control (3) clockwise to adjust the minutes
to the desired setting.
4. Turn the MULTI/JOG control counterclockwise
to adjust the hour and the “AM”/
Jan 28, 2010 | Vehicle Parts & Accessories
Teac R2 clock radio--Cannot set the clock.
Press and hold the CLOCK ADJUST button for more than 3 seconds.
"SET" and "CLK" appear alternately in the display.
Turn the MULTI JOG knob to adjust time.
Press the CLOCK ADJUST button again to finish.
Dec 29, 2008 | Teac R2 Clock Radio
Clock radio display doesn't light up.
I just got a similar model at Big Lots a few months ago. A T439S. There some funky stuff they do with those displays it could be that the lamp is wearing out. 7 years is good life for them.
Sep 03, 2008 | Timex T110TT Clock Radio
Clock
Here you can download user manual in pdf format
From page 107 on Manual:
"Clock operation:
The clock is on in the display regardless of
what mode, media, or function the radio is in
as long as the ignition is in ACC or ON.
Clock set
To adjust the clock, press the knob
for longer than 1.5 seconds. A beep signals
entry into the clock adjustment mode and
CL appears in the display. The hours will be
blinking. Rotate the knob to adjust
the hours to the desired level.
Press the knob a second time and
the minutes will start to blink. Rotate the
knob to adjust the minutes to the
desired level.
After 10 seconds, the radio or CD display
will reappear. Once the clock is set to the
desired level, press the knob repeatedly
until the radio or CD display reappears."
Jun 04, 2008 | 2001 Nissan Altima
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Set CD Clock Radio for Daylight Savings Time
just found a manual for another radio..timex website worthless but you hold the time or time set button down till the display starts flashing..then push the >>
Mar 11, 2007 | Timex T309TT Clock Radio
44 people viewed this question
 Grubhead
Grubhead
