Question about Rode NT1A Professional Microphone
Works for a few seconds then cuts out
My nt1a works for a few seconds then cuts out-lead, channel, ok. Phantom power switched on colin gibson
  • colin985 May 23, 2009
    Tried it on several high quality pre amps with no joy. Guess its going to have to go in for repair
    Problem Solver:
  • 5 Answers
After trying a known good cable, I would try it on another preamp (prefferably a medium or high quality one) with a known good phantom power supply and test it with that. Or just go to your local Guitar Center and ask the associate there to test it for you. They will be happy to oblige.
Posted on May 23, 2009
My Rode NT1a stopped working. I checked preamps
Repair of this mic is not something you can do yourself. This sort of failure is common, and I can repair it.
Sep 20, 2013 | Rode NT1A Professional Microphone
My Rode Nt1A also stopped working. I think its because i took the silica gel bag from the case. Should i always keep the mic inside the case after the usage. and i dont use a pop up filter
Removing the silicone bag and not using a pop shield can lead to condensation on the diaphragm. Place it in a bag of rice for a day to dry out any condensation on the capsule.
It may not be due to condensation though. Make sure your phantom power source is working. If possible attach another mic to the same source to see if it works. Check the contacts on the mic and also check the wire for any erosion or debris. If none of these work, fixing the mic may be beyond DIY repair.
Aug 31, 2011 | Rode NT1A Professional Microphone
Rode NT1A: i got an adapter so i can input it in the mic input the pc says an audio device has been put in but i cant find it anywhere! please help me i also have an Acer Z5710
The reason it is not being picked up by your PC is because the NT1A is a condenser microphone and it requires an audio interface that can supply phantom power (48V) to get it powered up. Without phantom power, the NT1A won't work. You many need to buy an external audio interface that provides phantom power to use the mic. Hope that helps.
Mar 03, 2011 | Rode NT1A Professional Microphone
No sound being picked up when connected, may be as I am using a xlr to usb connection and the power is coming off a laptop , how would I fix this? Thanks
The Rode NT1A requires phantom power of 24-48volts DC. The USB socket on your laptop will only supply 4.5volts.
The solution will be to buy a separate power supply or to connect it to your computer through a mixer that includes a phantom power supply option.
Feb 24, 2011 | Rode NT1A Professional Microphone
My Rode NT1a is not working, I have checked the phantom power and all cables which are ok.
If it is under warranty, I recommend sending it to Rode for repair. Otherwise, I can service any Rode mic. Condenser Microphone Mod Service
Jan 17, 2011 | Rode NT1A Professional Microphone
I'm buying a Rode NT1A, it comes with a shock mount, pop filter, xlr cable etc. What else besides a USB converter cable to I need to have this mic work it's full potential on a PC?
Hi, what else do you do think you will need? I don't think you will need any other thing except that before you use the mic, the switch for the phantom power on the microphone is to be activated .Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantom power on the mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
That all you will need .
Thanks for using fixya....
Oct 20, 2010 | Rode NT1A Professional Microphone
Does the NT1A work with the M-Audio MobilePre USB preamp?
The NT1-A will work with any mic preamp that has phantom power.
May 04, 2010 | Rode NT1A Professional Microphone
NT1-A just stopped working, Any ideas?
It could be caused by a range of things. but before blaming the mic, try a few things first.
To test it is actually the mic that is broken, and not any of your other gear, try using your current set up with another condenser mic. If this works, your mic is broken.
If you dont have another condeser mic available to you, try, one by one, replacing the cable, and changing the input channel on your mixer/interface.
When you try a different channel, choose an input that is on a different Phantom selector than your current one (most mixers/interfaces of 8+ channels will let you apply phantom to a group of channels, instead of all). If your mic works then, it could be an issue with your mixer's phantom power.
If all the above fails, then you should still be covered by Rode's 10 year warranty, provided it is not caused by missuse/misshandling (http://www.rodemic.com/warranty.php).
Nov 16, 2009 | Rode NT1A Professional Microphone
When I switch on my Rode NT1 - A mic - it is OK until I speak into it and it cuts off for about 20 mins. Then it comes on - then it cuts off when I speak or sing. Can you advise?
I had the same issue. The sound would fade and then go dead.. The preamp in the device I was using wasn't strong enough and also the phantom power seemed too low to sustain the microphone. After adding a TUBEPre by PreSonus, all of the issues went away and I was shocked to hear how good this microphone really is. Was the issue low phantom voltage/? or a lousy preamp? All I know is , after adding a preamp all of the problems went away.This has to be the best microphone I have tried in this price range.
Oct 17, 2009 | Rode NT1A Professional Microphone
Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
Rode NT1A Professional Microphone Logo
453 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Jay Plesset
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
