Question about Kitchen Appliances - Others
How to adjust Model WCR-11108 time setting
Whitewestinghouse WCR-11108 is a clock radio with two alarm setting. I cannot set the time or alarm settings.
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
  • 16 Answers
SOURCE: Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
Posted on Feb 22, 2009
  • 5 Answers
SOURCE: do not know how to turn off alarm setting for clock radio
Instructions are here: the closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Posted on Feb 21, 2010
jyackle5
  • 8197 Answers
SOURCE: Emerson cks3528 Dual alarm clock radio smartset
You can get the manual on the link below. Please alow time to load large file.
http://www.emersonradio.com/owners/SmartSet%20Series/CKS3528_110606.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Apr 24, 2010
Testimonial: "Thanks SO MUCH!!!! I've tried every button or set of buttons to set the "wrong" time zone for correct DST just to mess up Date too. Thank you SIR!"
jyackle5
  • 8197 Answers
SOURCE: alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Apr 29, 2010
How do set the wake up alarm on am/fm digital clock radio model ONB14AV201
1. With the unit in CLOCK mode, press and hold the ALM1/VOL+ or ALM2/VOL? button. The ALARM time will begin to flash on the LED display.
2. Press the ?/HR button to adjust the alarm hour.
3. Press the ?/MIN button to adjust the alarm minute.
4. When the correct time is selected, press the ALM1/VOL+ or ALM2/VOL? button to confirm.
5. Press the ALM1/VOL+ or ALM2/VOL? button to select the ALARM sound mode - buzzer or currently set radio station. The alarm buzzer or radio indicator will light up.
Jan 21, 2015 | Audio Players & Recorders
Cannot reset time on sony dream machine model no. Oct-c218
  • 1 Plug in the ICF-C218 in a well-ventilated area free of moisture.
  • 2 Press "Clock" if you are not in the U.K. and need to set the time manually. Hold it for two seconds.
  • 3 Press the + and - buttons until the year is set correctly.
  • 4 Press "Clock" once you've set the year, and repeat this process for the day, hour and minute.
  • 5 Slide the "Alarm Mode" toggle to either "Radio" or "Buzzer," depending on your personal preference.
  • 6 Slide the "Alarm Time Set" toggle to either the + or - side until you've reached the time you want your alarm to go off at. Hold it down to adjust in 10-minute increments
  • Read more: http://www.ehow.com/how_7396985_instructions-sony-icf_c218-clock-radio.html#ixzz2jjJEJSA3
    Nov 05, 2013 | Home
    Need to know how to set time on ISTA SET 40009
    Instructions
      • 1 Press and hold the "Alarm Set" button for five to seven seconds if you have an Insta-Set 40001, 44100 or 44200 model; the year will begin to blink when the clock is ready for adjustment. If you have an Insta-Set 40009 or 40018, hold the "DST" button for five to seven seconds (until the hour begins to blink).
      • 2 Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
      • 3 Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
      • 4 Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
    Read more: How to Change the Time on an Equity Insta-Set Clock ' eHow.com http://www.ehow.com/how_5657092_change-time-equity-insta_set-clock.html#ixzz1d1qIibS4
    Nov 07, 2011 | Equity Time USA Insta-Set 40009 clock
    How do you set the alarm clock for a model:38229-1 clock
    Press mode key at any time to exit.
    Press mode, then press adjust to change time zones.
    TO SET TIME AND DATE:
    Press and hold alarm on/off for about 5 seconds until hour flashes.
    Press adjust to change hour.
    Press alarm on/off to move to minutes. Press adjust to change minutes
    Press alarm on/off to move to seconds. Press adjust to change seconds
    Press alarm on/off to move to month. Press adjust to change month
    Press alarm on/off to move to date. Press adjust to change date
    Press alarm on/off to move to day of week. Press adjust to change day of week
    Press mode key to save to exit.
    TO SET ALARM:
    Press mode to go to alarm screen (AL shows above temp)
    Hold the alarm on/off button for about 5 seconds and the hour will flash.
    Press the adjust button to change the hour.
    Press the alarm on/off button again to move to minute
    Press the adjust button to change the minutes
    Press the mode key to save and exit
    Aug 22, 2011 | Audio Players & Recorders
    This clock is an automatic set clock and it is 15 minutes ahead in each timezone and is not able to be reset by us
    Press and hold the "Alarm Set" button for five to seven seconds and the year will begin to blink when the clock is ready for adjustment. .
    Press alarm 2 to change from Celsius to Fahrenheit.
    Press alarm 1 to change from 24 hr time to 12 hr time.
    Aug 08, 2011 | Equity Time USA Insta-Set 44200 Clock...
    I need the user manual for an alarm clock called clok. I can't set the time or radio stations
    These steps will only work while your unit is OFF. The power button is located at the top left face of the unit.
    How to set time?
    1. With the unit OFF, press and hold down the Clock/Display/Play/Pause button for at least 5 seconds.
    2. While still holding the Clock/Display/Play/Pause button, press the Hour, and then the Minute button to adjust the hour and the minute on the time.
    3. After selecting the correct hour and minute time, release the Clock/Display/Play/Pause button to set the clock.
    How to set the alarm?
    1. With the unit OFF, press and hold down the AL1 or AL2 button for at least 5 seconds. (an alarm icon will flash on the lcd display)
    2. While still holding down the AL1 or AL2 button, press the Hour and the Minute button o adjust the hour and minute on the alarm time.
    3. After selecting the correct time for alarm, release the AL1 or AL2 button to set the Alarm time.
    4. Press the AL1 or AL2 button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio or a docked iPod.
    Apr 17, 2011 | Audio Players & Recorders
    Need instruction for setting clock model # 38229-1 Atomic Clock - Sio/Scan (Equity Time). Need to set time, time zone and date. blainep
    Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
    Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
    Nov 29, 2009 | Audio Players & Recorders
    I need the instructions for alarm clock model number cc208s
    Please try this....
    Setting the Clock
    1. Press and hold the Clk Set Button.
    2. While holding the Clk Set Button, press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute.
    3. Release the Clk Set Button to set the time.
    Setting the Alarm
    1. Press and hold the Alm Set Button.
    2. While holding the Alm Set Button , press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute for the alarm time.
    3. Release the Alm Set Button to set the time.
    4. Adjust the Auto/Off/On Button to Auto.
    5. Adjust the AM/FM/CD Switch to the desired function for the alarm, or reduce the Volume Dial to "Buzz" to wake to the unit’s buzzer.
    Cheers!
    Jul 13, 2009 | Audio Players & Recorders
    Alarm clock won't change time with daylight savings
    unless it is an automatic , atomic clock none I have ever owned do the change automatically
    Feb 27, 2017 | RCA Audio Players & Recorders
    Virgin Pulse model VP-07 CD clock radio
    1. To set the clock to leave the unit in standby mode. (Plug in the AC cord to a wall outlet without switching unit on). 2. Press SET button for about five seconds until AM--12:00-- stops flashing. 3. Press down TUNING button to adjust hour, and up TUNING button to adjust minute. 4. Press SET button to confirm time set.
    Sep 11, 2007 | Virgin Pulse VP-07 Clock Radio
    Kitchen Appliances - Others Logo
    44 people viewed this question
    Top Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
