How to connect wii to tv - Televison & Video
How to connect my wii to a cable box with my Emerson TV?
You cannot connect wii to a cable box. You have to connect your wii straight to the TV using the red, white and yellow connection cables that came with wii. If your TV is older and only has a coax cable connection then you need a rf modulator
Feb 09, 2015 | Emerson Televison & Video
There are no connections for the red whits and yellow AV cable in the new smart TV can i eliminate this cable and use a USB cable in its place this is for a wii
The usb port in Wii is for input devices (i.e. external HDD, Wii keyboard etc.) and can't use it to output signal going to your TV , its only the AV cable supplied by wii you can use to connect to tv. If the TV has no RCA input (yellow, white & red connections) you can buy AV to HDMI adaptor or AV to VGA adaptor to connect your wii to your new tv model.
Sep 29, 2014 | Nintendo Wii Console
Connecting wii to Sony bravia tv
If you have an old V.C.R that has Red, White and Yellow sockets for AV and it still works then plug it into the RF socket tune the V.C.R to your TV and connect your Wii to the Red,White and Yellow R.C.A connections and you should be playing in no time. I have done this myself on a new Samsung TV it will work. If you have no V.C.R and you have HDMI sockets in your TV you can buy an adapter to convert the existing AV port on the Wii to HDMI then simply connect a HDMI cable (if you have 1 if not they are cheap enough off eBay starting at $6.00+AUD or around $20.00AUD Retail) to the Wii and then the TV ensuring that both the TV and the Wii are powered down prior to connecting any cables at the back. The HDMI Adapter for Wii is available on eBay from $5.00 AUD to $24.95AUD depending on the country you purchase it from. If all else fails a second TV with Red, White and Yellow RCA plugs will work but also the most expensive of the fixes. All fixes suggested will work. Good Luck I hope this helps.
Jan 12, 2013 | Nintendo Wii Video Game Consoles & Games
I'm trying to connect to the internet from my wii with my tv to watch netflix... how do we connect to the internet
Connect your wii using a Ethernet cable from the Ethernet port on the back of your wii to the router, or connect the wii using wifi.
The wii t your tv as usual and that's it.
Mar 17, 2011 | Computers & Internet
How do i connect a nintento wii to my sony home theatre system model htsf 470?
Hi beejaysaunde,
To connect your Wii to the htsf 470:
1. Connect your Wii to your TV.
2. Use a separate audio cable (red/white) and connect from your TV to your htsf 470.
3. Choose the correct selection on the htsf 470.
This setup will have your Wii's video go directly to your TV and the Wii's audio to be sent to the stsf470.
I hope this helps.
Dec 26, 2010 | Sony HT-SF470 Theater System
Can i connect my wii console to my tv thru my dish network dvr
I hope that you have found the proper solution for this. The Wii console only has an "out" port, no "in" ports. This means that you can only connect the Wii to the tv, and nothing to the Wii, so you are not able to connect this between your receiver and tv.
Becki Barned
DISH Network Customer Service
Oct 22, 2010 | Nintendo Wii Console
How can i connect Nintendo wii to avr-590. Have
To connect a Nintendo Wii to an AVR-590, I am assuming this is a Denon Receiver, you will need to connect the Nintendo Wii to the TV, then connect audio out from the TV to the AVR-590 Receiver, and select the receiver to be in Pro Logic. Depending on the TV, if you have fiberoptic output on the TV, you would hook a fiberoptic out from the TV to the AV Receiver, but you will still not get true Dolby Digital, just Dolby Pro Logic. This will be the most effective way to solve the problem. Hope This Helps
Geek Squad
Dec 28, 2009 | Electronics - Others
How to connect wii fit? no red white and yellow sockets on tv
i belive the wii fit connects direct to your wii console and console to tv
May 30, 2009 | GE 25GT240 25" TV
Nintendo wii to lcd tv
How do I connect my WII to my Panasonic lcd tv ?
Mar 30, 2008 | Nintendo Wii Console
Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Dec 28, 2007 | Televison & Video
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
