Question about Stihl Garden
How to start a stihl sump pump - Stihl Garden
I have a Stihl Weed eater will a FS 45 carburetor fit on an FS 90
NO. The FS90 is a 4mix engine and the carb has a (sump) on it which has a pulse pipe going to the bottom of the crank. The FS45 is a totally different carb configuration, and doesn't have the sump. FS90 carb is an C1Q-131A
The FS45 has several carbs that fit:-
C1Q-S97
C1Q-S71
C1Q-S66
C1Q-S58
C1Q-S44A
C1Q-S53A
Apr 13, 2016 | Stihl Garden
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Sump pump
I am presuming you're asking about a basement sump pump, the kind that keeps your basement dry. Well, those things are not meant to run all the time. They are usually triggered by a float valve. That is a device that moves according to the water level in the sump (in other words, the hole). When the water gets high enough, the float activates a switch, the pump kicks in, the water is flushed away, the float falls and that turns the pump off until the cycle starts all over again. The frequency of the cycle depends on how fast the sump fills itself. I have one that kicks in five times a minute. Another might have a much longer off time. But don't be worrying about yours not being on all the time... that is how they are supposed to behave. Of course, if you have water flowing out the top of the sump, that is a sign things are not right with the pump. Then you really need help.
Jun 25, 2014 | Health & Beauty
Chainsaw rattles when it stops
personally too much hassle prefer Stihl Chainsaw more reliable Seizing is caused by lack of lubrication, First check all level has oil pump seized or is it sump type when running oil circulates all way round, Still there has to be a oil reservoir if this is bone dry theres your problem the rattling is metal on metal with no protection and the damage is seizing caused by lack of oil I have two chainsaws both have oil sumps and are kept full, please check hope this helps
Feb 15, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Grey hotpoint washing machine wt741g i would like to know what f05 means water still in drum only a little bit of water but when it gets to the last 30 minutes it starts flashing f05 and wont turn off
f-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
from,
hotpoint ace
Sep 10, 2010 | Washing Machines
Sump pump float
The switch has failed. Replace it with a new mercury type rated to handle the pump.
Dec 29, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
The water fills the tank but does not go out of the hose and drain to the sump pump as designed
Check the hose for clog up as well as your sump pump. Have your hose unclogged and let it run. Check the sump pump if this is running. And if it is, and still no water goes out. Open the sump, and check the impeller for defect. Impeller is the one that turns around to push the water out. If it is defective, you must replace it to make it run.
Once you are done, power it up and start it.
Sep 27, 2009 | Haier HDN655E Dehumidifier
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
